3rd, 5th gear goes into neutral on deceleration..
So this just started happening yesterday and I am thinking it is the linkage roll pin. When I was in 5th gear I decelerated and went to accelerate again at 55 mph and it just revved the engine. I noticed the shifter had slightly moved out of 5th gear into neutral and it only does it with 3rd and 5th. I also noticed when going into 1,3,5 it seems a like it is reaching out to get all the way in gear this is why I am thinking it could be the roll pin and hopefully not the internals. Thank you for any assistance.
This happens to me every once in a while. I always thought I didn't shift into gear properly.
more than likely the linkage itself, not the roll pin. probably just popped out of the connector on top of the transmission
(Post 5946886)
yes it'll be obvious once you see it
(Post 5947404)
