Any tips for a trans rebuild??
Old Oct 21, 2013 | 12:53 AM
dieselfever1's Avatar
I am about to rebuild my trans in my 05 lsj, not sure if its LSD or not. I have a lift and all the tools ill ever need. Im looking for tips/tricks on what to buy, what to upgrade and just a general list of things that might make my life eaiser.
this is what its doing
It wont go into 2nd unless im completely stoped (syncro?)
makes a roaring noise, faster i go louder it gets (TOB or Output bearing)
I have researched and found that i should do a LNF TOB, but thats all ive came up with so far
ANY advice would be great!!!
Old Oct 21, 2013 | 01:10 AM
AyrtonSenna's Avatar
Why don't you get the zzp 6 speed conversion kit?
Old Oct 21, 2013 | 05:55 AM
Wert842's Avatar
Cause its like 4gs+ when all said and done.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Oct 21, 2013 | 06:56 AM
Just be careful, take your time, label things if you need to. Try and find a service manual or use an online one like alldata.
Old Oct 21, 2013 | 08:35 AM
armcclure's Avatar
Are you sure you have all the tools needed? There's some getrag specific tools that without them it's nearly impossible to split the case without cracking it.
Old Oct 21, 2013 | 08:44 AM
cryotreat everything
Old Oct 21, 2013 | 08:50 AM
blueLNFftw's Avatar
use an OBX dif.
Old Oct 21, 2013 | 09:04 AM
Tjolley's Avatar
Splitting the case is the easy part. Getting the gear sets out and Back in is the bitch.
Old Oct 21, 2013 | 01:21 PM
Powell Race Parts's Avatar
fyi not a getrag trans. good luck.
Old Oct 21, 2013 | 01:23 PM
use an OBX dif.
dont listen to this idiot
Old Oct 21, 2013 | 01:24 PM
blueLNFftw's Avatar
Hi my name is sarcasm, nice to meet you.
Old Oct 21, 2013 | 01:25 PM
right back atcha
Old Oct 21, 2013 | 02:05 PM
advise's Avatar
Not easy I tried and failed even with the service Manuel
Couldn't seem to find the 1st And 2nd installation spacer tool
And have fun with the leaf springs
Old Oct 21, 2013 | 07:18 PM
most people break fifth gear trying to take it apart. fyi.
Old Oct 21, 2013 | 07:41 PM
Is this tranny really that complicated?
Old Oct 21, 2013 | 09:15 PM
not if you have done a few. If you havent done it before, its a learning experience. which means lots of tears and hardship pretty much.
like bleeding the clutch. its so simple.
how come thats the #1 issue on here?
Old Oct 21, 2013 | 10:12 PM
andrewcarr1993's Avatar
How hard is it for the F23, I want to add an LSD (real quaife one) when I have it out.
Old Oct 21, 2013 | 10:34 PM
andrew that will be hard I am not sure if quaife has a unit that will work on the f23. there is a " green " something or other lsd that folks use with some massaging that works well I am told, I have no direct experience with the unit
Old Oct 21, 2013 | 11:04 PM
It was originally designed for the F23 off of some European car but should fit any F23.
TTR sells them but they overpriced it by about $280 from the other sites you can find it.
http://turbotechracing.com/productca...dcategory=5615
I realized I could either buy a set of autocross slicks or an LSD which will benefit everyday driving, I'll probably have a shop rebuild the transmission and install it so when it goes back in it's practically new. If FMSR sells one for about 2k I'll probably just get that.
I'll have to remove a wheel and send you some pics of the Brembo's at some point, but between school and work I only have two nights a week free. I appreciate the response, P.S. how is the rear disk conversion coming along?
Old Oct 21, 2013 | 11:13 PM
Quaife LSD Chevrolet Cavalier Pontiac Sunfire 2002-05 - Cobalt 2005-10 2.2/2.4L Ecotec - Drivetrain
rear conversion is ready anytime you are drum to disc. ps thanks for the link on the quaife i have to deal with that for a customer so I will email quaife in UK on this and some other things i need to know; I have found changes to the quaife in some later my TC F 35's.
Old Oct 21, 2013 | 11:19 PM
Is it priced yet? I need to start saving if so.
If you are willing to rebuild the F23 and put in an LSD let me know.
I really need to make a trip to your shop sometime soon.
Old Oct 21, 2013 | 11:29 PM
the basic kit is 225 just add calipers and rotors. email me
Old Oct 22, 2013 | 12:33 AM
where can i get a rebuild kit for the f35? anywhere? cant seem to find ****
Old Oct 22, 2013 | 04:43 PM
advise's Avatar
What do you need I have 2 of everything lol
And I hope your having someone do it for you
Old Oct 22, 2013 | 11:11 PM
Powell rebuilds them rice.
