Axles
Old Feb 23, 2010 | 09:53 AM
boricua s/c ss.'s Avatar
Axles
i need new axles. does anybody know of good axles that are not to much $. i saw the ottp stage 1 axles. does anybody have these. or should i just get one from autozone or places like dat
Old Feb 23, 2010 | 10:49 AM
MT0911's Avatar
OTT Stage 1 axles is definitely a great deal for the cost and the quality, plus OTT is a great vendor, always great customer service. PM them for more information on the axles
Old Feb 23, 2010 | 10:54 AM
does the car launch better with better axles.
Old Feb 23, 2010 | 10:56 AM
northvibe's Avatar
if you go to a auto parts store and order axels for your SC, you may just get the cheap axels. Id recommend getting some gmpp axles or ottp so you wont snap them as easy.
ShortStack's Avatar
Gain has Really has nothing to do with this....
Old Feb 23, 2010 | 11:02 AM
miele has some dss axles. do u think they are good. or they wont last to long
Old Feb 23, 2010 | 11:12 AM
recklessactn's Avatar
ok, i know your new and you have some issues so lets start with where or who did you buy your car from and what did they tell you what was done with the car.
Your car if it is "stock" like you said it was in your other thread and you have the dss axles in, someone obviously had the car modded before you bought it and was making some power bc the dss2 axles are bought bc you either snapped your oem axles or your dragging your car.
Old Feb 23, 2010 | 11:31 AM
no. i got the car in 05 brand new from the dealer. i said that miele auto parts has the dss axles for 73 each. they replace the stock ones. i was asking if they are good axles. yes im stock.
Old Feb 23, 2010 | 12:55 PM
MT0911's Avatar
^ did you snap your current axles? if your car is completely stock then your axles should be fine... unless you're planning on upgrading significantly (TVS, Turbo, etc.) and then tracking your car. You asked if better axles give you better launches... well if you're just looking for better launches I would say buy some trans mounts and/or an engine mount (depending on what type of trans mounts you get)... OTT and TTR have some pretty good sets you should look into...
Old Feb 23, 2010 | 02:31 PM
no my axles didnt snap yet. when i turn towards the left and right they start making weired noses. im planing on just getting stage 2
Old Feb 23, 2010 | 02:37 PM
Supercharged Guy's Avatar
Go get the ZZP stage 1 or the OTTP stage 1 they're both the samething and the same price. rated 325hp
Old Feb 23, 2010 | 04:14 PM
If you know its the axle causing the problem then just upgrade to the stg1 like supercharged guy said for better launches def. go with ottp rotated mounts stg1 for no vibs almost no wheel hop, stg 2 for some vibs at low rpm and no wheel hop.
Old Feb 23, 2010 | 08:22 PM
MT0911's Avatar
^^ I agree. If you want almost no vibs at all and no wheel hop: OTT Stage 1 Axles + OTT Stage 1 Rotated Mounts = WIN, but if you're like some who like a little vibs for a stiffer ride then you could consider: OTT Stage 1 Axles + TTR STOP Trans Mounts (they use poly), either way you go is great and will make a noticeable difference that you will feel 24/7 good luck man
chefhhr
Oct 26, 2015 10:36 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
ROADKONE
Sep 9, 2015 02:32 PM
