Axles
Old Oct 18, 2012 | 02:01 AM
Fastgti69's Avatar
Axles
Replacing my front right axle. ACDELCO Part # 20778308
Was wondering do I need to get transmission fluid? I'm only changing the right side which from what I remember isn't directly connected to the tranny. So I don't think the tranny will leak oil. I just want to make sure so I don't get fucked in that situation.
thanks!
Old Oct 18, 2012 | 09:30 AM
blueLNFftw's Avatar
no.
it goes into the intermediate shaft.
dont unbolt the shaft to engine block bracket at all.
take the hub off, get underneath and tap the axle out of the shaft by the base.
this is a <30 job with hand tools.
Old Oct 18, 2012 | 09:32 AM
Dart_SI's Avatar
you wont need it, but its always nice to have some spare trans fluid on hand just in case. and oil, and coolant... lol.
agreed that it only takes like 30 mins. very easy to do.
Old Oct 18, 2012 | 09:36 AM
Squints's Avatar
Are these axles you got performance grade or just normal axles has no effect on the job just was wondering
Old Oct 18, 2012 | 10:44 AM
Fastgti69's Avatar
no.
Thanks guys, I'm going to order that stuff now.
No, stock axles for the LNF. Was wondering tho LSJ axles fit? They're literally 60$ vs 150$ LOL they seem to have same measurements too.
Old Oct 18, 2012 | 11:24 AM
startingline05's Avatar
Lsj axles are weaker plus you would have to change something else, just dont remember what lol
Old Oct 18, 2012 | 08:34 PM
Fastgti69's Avatar
Yea lol, that toallymakes more sense.
Old Oct 18, 2012 | 08:49 PM
Powell Race Parts's Avatar
LNF axles have larger diameter hub splines. LSJ axles dont fit an LNF. LNF axles are stronger by far.
Old Oct 18, 2012 | 09:22 PM
Fastgti69's Avatar
Thanks for that bit of info, important to know. I will be contacting you for some sway bars and possibly springs
Old Oct 18, 2012 | 10:12 PM
Noproblem. the LNF axle can be had with LSJ end bells, that fit, its made by GM and part of the "anti power hop kit" sell for over 500 dollars comes with LNF mounts as well/ contact CED for those parts
Old Oct 18, 2012 | 10:34 PM
Fastgti69's Avatar
Aww crap. Thank you for this, I already ordered the right half axle.
Old Oct 22, 2012 | 03:13 AM
AyrtonSenna's Avatar
Just wanted to ask one thing since I'll build my motor and looking to be in the 600ish whp: do I need to get stronger axles or the stock ones will be fine? I have a SS/TC.
Old Oct 28, 2012 | 12:13 AM
Fastgti69's Avatar
Installed axle. Ride got smoother but still shakes a little bit at higher speeds during acceleration. Maybe lower control arm? I don't think it's the hub bearing. I'm running out of things. I don't think its my steering. I gotta check the tie rod ends too. I don't know. Anyone can give me any more clues on what it could be.
Old Oct 28, 2012 | 09:28 AM
With a 600ish whp do I need to get the axles from driveshaftshop? Or the stock ones will be ok?
Old Oct 28, 2012 | 12:16 PM
Stick with your stock axles until they break, rather break an axle or your transmission? Also would like to know more about your build and what turbo your using for your 600 hp build.
Old Oct 28, 2012 | 03:39 PM
what does the tranny has to do with the axle?
Old Nov 1, 2012 | 01:24 PM
blueLNFftw's Avatar
with a question like this I feel your 600hp is an unrealistic dream.....
Old Nov 1, 2012 | 01:33 PM
MP Cobalt's Avatar
Keep the stock axles till they break axles are more forgiving to replace. NAPA axles also one breaks it's replaceable hahah
Old Nov 1, 2012 | 01:35 PM
MP Cobalt's Avatar
lol
Old Nov 1, 2012 | 01:41 PM
sLAsh's Avatar
You put out big power and the weakest link breaks first. Cheaper to replace axle than a tranny.
chefhhr
Oct 26, 2015 10:36 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
ROADKONE
Sep 9, 2015 02:32 PM
