b-woody traction bars??
Old Mar 24, 2008 | 09:01 AM
Altiery54's Avatar
any1 have them on if so what do u think of them. do they help alot or are they worth the $200. can u run traction bars and a TTR motor mount at the same time?
Old Mar 24, 2008 | 09:10 AM
D4u2s0t's Avatar
i don't see what traction bars have to do with the motor mount, so i would say it should be fine. haven't heard too many reviews about the traction bars yet, i'm considering buying them also.
Old Mar 24, 2008 | 09:52 AM
Rodimus_Prime's Avatar
They are worth every penny
Old Mar 24, 2008 | 09:54 AM
lsjwannabe's Avatar
seem to be good, you just have to dial them in and lube them up so they won't squeak
Old Mar 24, 2008 | 09:57 AM
Maxim_X's Avatar
Just adjust them right. It takes a while. I use them.
Old Mar 24, 2008 | 10:00 AM
lsjwannabe's Avatar
Any noise from them?
Old Mar 24, 2008 | 11:33 AM
celicacobalt's Avatar
i heard the original design sqeaked alot but the newer design has some type of bushing added now that gets rid of that problem.
Old Mar 24, 2008 | 11:36 AM
lsjwannabe's Avatar
have to look into that
Old Mar 24, 2008 | 11:59 AM
ebristol's Avatar
I think they blow.
I had the latest bwoody design with the rubber bushings that "reduce noise". When I was completely stock the bars worked well. I had them dialed in to the point where I had very little wheel hop. But no matter how often I greased them they still squeaked and creaked like a cheap hotel box spring and mattress. Its very embarrassing....
Once I got GMS2 installed they became completely worthless. I spent hours adjusting and re-adjusting the t-bars. No matter what I tried they didn't work. Sure they "reduced" wheel hop but never got close to reducing it to the level I had when I was stock. So I ended up getting rid of them and buying SMMs.
The top mount is from Turbo Tech Racing and the trans mounts are from ZZP. I have not installed them yet because its too freaken cold!! But most veteran lsj owners will tell you to skip over the traction bars and go right to solid motor mounts.
Old Mar 24, 2008 | 12:10 PM
rallycobalt06's Avatar
right now i have the TTR tranny bushings & Ingalls TD, i have absolutely no wheel hop. but i am switching from the TD to the TTR SMM. selling my Ingalls TD.
Old Mar 24, 2008 | 02:54 PM
I shy away from solid motor mounts now simply because my last car was like a huge vibrating ***** of resonance at 80mph to the point I had to shout to get through to passengers sitting right next to me
Old Mar 25, 2008 | 12:32 AM
syP's Avatar
syP
had it... hated it.. took them off and put on trans mounts..
have not wheel hopped since
Old Mar 26, 2008 | 04:15 PM
tru2nrtt777's Avatar
Eh, I am like that with just my catback.
Old Oct 30, 2009 | 01:39 AM
Cobaltsky05's Avatar
had them didn't notice much difference, but I already had lower poly mounts... now I have a ttr upper mount and no bars much better for hop and cornering. I noticed installing these on my 2.2 was almost impossible even with the spacers and hardware supplied. I bent a rod I that was supposed to be full race upgrade the first two weaks driving. Sold now...
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
