Bench bleeding the TOB
Old Dec 13, 2014 | 05:40 PM
LNFwagonSS's Avatar
I know what your thinking...don't bench bleed the TOB because it can cause it to over extend. I'm not talking about introducing any pressure into the TOB. I want to make the bleeding process a little easier by starting out with a TOB that already has fluid inside. If you depress the TOB, when it's released it will create suction. Has anyone attempted to suck fluid into the TOB prior to bolting the trans on the engine? I realize fluid will be forced out of the TOB line when the trans is pushed closer to the engine, in which case, you can simply catch the fluid with a tube connected to clutch pipe routed to a container to catch the expelled fluid. I don't see any risk with doing it this way but would like some input in case I'm overlooking something. This would undoubtedly make bleeding our hydraulic clutch system much easier if TOB was already full.
Old Dec 13, 2014 | 06:10 PM
blueLNFftw's Avatar
Just hook everything up, open the bleeder, and full the system. Let it sit and gravity bleed
For a couple hours.
Old Dec 13, 2014 | 06:16 PM
LNFwagonSS's Avatar
For a couple hours.
Is this with or without the method I posted above? If TOB was already full I wouldn't have to wait for anything at all. Just connect line to TOB pipe and bleed the little bit of air from the line that goes to master cylinder.
Old Dec 13, 2014 | 06:47 PM
blueLNFftw's Avatar
Instead of doing what you said
Old Dec 13, 2014 | 06:48 PM
blueLNFftw's Avatar
Especially if you have a self adjusting pressure plate. You do not want to pump the **** out of a PP that self adjusts. Gravity bleed and them vacuum bleed with like 10-14in/hg
Old Dec 13, 2014 | 08:40 PM
LNFwagonSS's Avatar
The stock Sachs f40 pressure plate I will be using is self adjusting. I do not plan on doing much bleeding, if any, with the pedal. If TOB is full with little to no air inside I could vaccum bleed at the bleed nipple with my mityvac. That was my plan anyway. Just wondering if anyone has tried this method with success.
Old Dec 13, 2014 | 08:48 PM
blueLNFftw's Avatar
It's pretty much the same idea as what I said only with what I said you won't have fluid spilling out as you try to install the trans.
Old Jan 11, 2015 | 01:50 PM
LNFwagonSS's Avatar
Bump. Anyone tried this?
Old Jan 11, 2015 | 02:05 PM
09CobaltSS1's Avatar
I'm ironically enough buttoning up a clutch job for a customer at my shop as I type. With that said, don't do it. There's just no need for it. It's easy enough to bleed the system with a vacuum pump. Don't overly complicate it my friend.
Old Jan 11, 2015 | 02:06 PM
Omiotek's Avatar
^^^this either vacuum bleed it or do it with 2 people
Old Jan 11, 2015 | 03:17 PM
67C10's Avatar
I thought about doing it as well, but got advice from this site and did it via vacuum. No problems and no chance of catastrophic failure.
Old Jan 12, 2015 | 12:18 PM
LNFwagonSS's Avatar
Thanks for the input fellas. I guess I'll just gravity bleed then vaccum bleed.
Old Jan 12, 2015 | 12:26 PM
LNFwagonSS's Avatar
Would you mind giving me a rundown of your step by step bleeding procedure?
Old Jan 12, 2015 | 01:10 PM
blueLNFftw's Avatar
I just put 20hg/in vacuum on it and let it sit for 10 min. Give it a couple pumps under vacuum.
Repeat twice and then I do traditional bleeding.
Old Jan 12, 2015 | 02:57 PM
Sure. It's actually very easy and really takes no time at all to do. First and foremost, it is very important that, if you are using an adjustable clutch rod, the clutch rod must be COMPLETELY adjusted ALL THE WAY IN (shortest length). If not you run the risk of blocking off the fluid passage from the reservoir to the rest of the lower clutch system.
Simply remove the hard line going into the distribution block (aka elbow) and let it hang as low as you can get it into either a catch can or small bottle.
Next remove the cap from the reservoir and over fill the reservoir a good ways (any excess can easily be drained and/or pumped from the system after words).
With the clutch pedal in the "up" position, simply let the system drain. Within a minute or 2 fluid should start trickling out of the tube.
Once you see a steady stream of fluid coming out, then go ahead and connect the line to the distribution block.
With the line connected, open the bleeder valve on the distribution block and let air and fluid drain for a minute or 2 into a catch can. Once a steady stream starts flowing, go ahead and close the bleeder.
With the bleeder valve closed, connect a vacuum bleeder (the vacuum bleeder MUST have a gauge built into it in order to know how much vacuum is being drawn) and build roughly 20inHG of vacuum. Open the bleeder slowly until you start to see the vacuum pressure drop, and let it continue to drop until stop hearing suction. You should hear a combination of air and fluid come out at this point. Close the valve, and continue with the pump until your catch can is now filling with pure fluid. Just be sure to keep a close eye on your fluid level at all times. Never let it drop below the "Min" mark or you could risk introducing air back into the system.
At that point you should be pretty well bled out. Pump up the pedal a few times and make sure it returns to the top each time. After I vacuum bleed it, I'll usually call over a second set of hands and have them look inside the inspection cover and verify the TOB is cycling properly. I'll also have them pump up the pedal a few times, hold it to the floor, and crack the bleeder with my vacuum pump connected just to verify every bit of air is out of the system. Close the bleeder, reach down to manually pull up the clutch pedal, verify fluid level is good and you should be good to go for a road test.
Old Jan 13, 2015 | 03:45 PM
LNFwagonSS's Avatar
This is by far the best, most detailed description for bleeding the clutch system for our cars I've seen so far. Thanks for all the info John!
Old Jan 22, 2015 | 11:26 AM
kzak104's Avatar
That's a lot of words just to say open the bleeder fill res pump pedal till fluid comes out closer bleeder refill res and bleed normally with a friend...
Old Jan 22, 2015 | 02:07 PM
LNFwagonSS's Avatar
Actually he wasn't describing the pedal pump method at all. That method sucks anyway. Minimal pedal pump is the goal here
Old Jan 22, 2015 | 03:25 PM
kzak104's Avatar
Never had issues. Bled tons of clutches.
Old Jan 22, 2015 | 07:25 PM
There's the right way for doing things, there's the half assed way of doing things and then there's the guy who things he's clever by explaining away something in one sentence.
Correct procedures tend to need a little more explaining than just a silly 20 word explanation that only states the clear obvious. For those who may not be as familiar with a clutch system, there needs to be more details involved.... especially when the job at hand calls for it. For example: Define "bleed normally with a friend". That means utterly nothing to someone reading this who might actually be looking to learn something. Unfortunately, judging from your simplistic explanation above, I'm guessing you likely have quite a bit more to learn yourself there.
Old Feb 9, 2015 | 09:39 PM
Your way does sound very sound and thorough. After trying to do it alone yesterday by bleeding it while pumping, i did it by the build book.
Which was as follows and seems fishy..
Connect vac bleeder to resiovior. Mine didnt have an attachment to screw into the cap so i left the cap on and attached to the open 1/4 neck protruding from the top of the res,
Pump vac bleeder to 15, wait for ten minutes.
Relieve pressure, pump clutch 10 or so times, then do it again a few more times waiting 5 minutes in vacum each time.
Idk far as i can tell im feeling normal clutch pedal pressure. But idk how the vac method actually pulls any air.
Old Feb 9, 2015 | 09:57 PM
royce777's Avatar
subd
Old Feb 10, 2015 | 12:11 PM
yeah me too haha
Old Feb 10, 2015 | 10:48 PM
kzak104's Avatar
Old Feb 10, 2015 | 10:51 PM
kzak104's Avatar
If your referring to me I have bled many many many clutches at work. Never had a come back. Including power assisted Porsche systems.
But I understand people who have never done it before over thinking it and getting themselves psyched up
