Best Clutch
Best Clutch
I have an 06 cobalt ss supercharged and my clutch is slipping so i think its time for a new one. what are the best clutches out there for my car. i have so mods done to my car also
I just put in ZZP stage 3 with new GM flywheel and the upgraded (LNF) throwout bearing. I LOVE it. Holds great. Starting out in 1st gear is a little touchy, but not as touchy as the SPEC stage 3 I had in my last car.
I've got 2,000 miles on mine so far, and it's been awesome.
no need for anything but the lsj upgraded clutch on a stock engine. anything designed to hold more power will typically have more mass and will reduce the power you put to the ground. you never want to add unnecessary rotational mass to the drivetrain.
interesting read...just doing a rebuild and ended up going back to lsj stock clutch...handles 300hp and i'm probably right on that cusp...got it from crateenginedepot.com probably one of the best prices out there also
Putting a clutch similar/slightly upgraded from stock, limiting future mods. Along with a stronger clutch will last longer, as you are not stressing it nearly as much.You dont want to replace a clutch twice, it gets spending with all the install labor.
You never want to limit yourself though.
Your choice, that is all we will say. We dont just sell KY kits everyday just because.
Im going to revive this as ive searched high and low and cant fins what im looking for.
I have a stage 3 LSJ 2.8 pulley and 60s... So on and so fourth.
My mechanic is a southbend dealer and can get me a good deal on their clutches... So i was wondering of i would surpase the 300ftlbs for the SB stage 2 or GMPP clutch.
Basically... Will the South Bend stage 2 hold on a stage 3 m62 setup?
put it to you this way man, im running the upgrade clutch on my lnf and its making 357whp and 375wtq ive had it now for 2 years and it hasnt slipped once for me so unless your guy can get you a better deal on a south bend then id def go gm upgrade clutch
When you buy a SPEC, you get one with the non-ratcheting pressure plate.
The self adjusting pressure plates, on any clutch, (IMO) are a dumb feature. They just seem to cause everyone problems and I dont care if my clutch grabs in the same spot. I would rather the engagement move so that I can tell my clutch is getting closer to being at the end of its life.
19212712 Cobalt Clutch Upgrade Kit at GM Performance Motor & Parts
Ok I found this to be cheaper than the CED kit...
I can get it from this ite 285shipped... But CED has it at 309 shipped eith the clutch pipe and alignment tool.... I am having a local shop do the install...
NOOB! Basically do I need the clutch pipe and alignment tool?
I didnt order from CED and I am more than likely not getting the clutch pipe...
Why do we NEED the clutch pipe?
I know someone with the alignment tool so thats fine... But I still dont understand the necessity of the clutch pipe.
Here's exactly what and where I ordered...
http://m.summitracing.com/parts/NAL-19212712
Chevrolet Performance 19212712 - Free Shipping on Orders Over $99 at Summit Racing
