Best traction/torque improvement
1. Trans Mount: ZZP or TTR?
2. LSJ Axles: ZZP or?
3. Clutch kit: Spec, Exedy, ACT or ZZP
4. Flywheel: Fidanza, Spec or Cluthmaster?
5. Stat bar?
6. Limited Slip Diff?
Among this mods, which would be first or the one that produces more torque or traction.
What do you think?
5. Stat bar?
What do you think?
TTR engine mount
clutchmaster stage 4 clutch
clutchmaster flywheel
wider tires
5. Stat bar?
What do you think?
5. Stat bar?
What do you think?
These things will allow you to take more advantage of your torque/traction.
How much power do you have? Because really, these are things all needed, unless you are stock
Anyway, What I currently have in installation is: TTR engine mount, OTTP stage 2 tranny mounts (TTR STOP tranny mounts also do the job), Ingalls, Clutchmaster stage 4 and flywheel.
When I get the car back, will see how they are
Lady Gaga Traction Mod
Tools needed:
Ductape
Ugly Ass Lady Gaga's Head
Directions:
1 -Ram her ugly face between the lip of your car and the pavement - if your car is lowered and she doesnt fit well kick her face until its equally spaced under the lip and the pavement
2 -Open her mouth so her knarled up teeth are dragging against the pavement. If she wont open her mouth punch her a couple times. This should release the pressure and you can proceed with this step
3 -Once into position and with mouth open ductape her head to your lip and check for any wobbling. Apply more ductape as needed.
4 - Try launching car at high rpms. If done right her ugly ass face should take the wheel hop and cushion it resulting in no wheel hop. Her messed up crack teeth should also shave the road as you drive resulting in a smooth riding surface at all times. Be care ful on potholes as it might chip a tooth
Enjoy your new traction mods! Post pictures if you decide to go this route
Tools needed:
Ductape
Directions:
