Broken Tranny or Something less Serious?
Ok guys, I'm at the gas pump putting in 20 dollars turn the car on and pull out to the stop sign, everything normal. I go to pull out from the stop sign and the car wont move anywhere and all i here is a terrible clunking noise like something is spinning around and banging stuff in the tranny. What do you think bad tranny or something else?
sounds more like your muffler bearings.
good one
auto or manual?
manual
Maybe the throw out bearing broke
First thing I would check is the axles man does it go into gear still if so don't think that the throw out is bad
its not leaking fluid and the axles are good. and it goes into gear no problem
oh and the throw out bearing was replaced with the clutch a few months ago along with the flywheel |
Originally Posted by nfarrall
(Post 5890309)
or the flywheel.
