Bwoody Traction bars Click/Clank/Tick after install.
not sure if i installed them too tight or what,
but when i am taking off (normal driving) its ticks a few times, and when braking it ticks as well.
if this keeps up, i am taking them off... Are there any problems with these that users have been having?
also, how tight was i supposed to tighten the bolts on the frame and control arm?
**Well i read the install thread.... i adjusted them when the car was IN THE AIR (wheels off the ground)
do i need to adjust the bars with both wheels having full weight on them (on the ground?)
think that could be my prob?
i have/had the same issue...you'll just wanna make sure that you have the bushings installed and also that you have the traction bars themselves tightened properly to the frame.
its just the bars moving back n forth in the bolt holes...
DANRICKARD
10-01-2015 12:08 AM
