clutch peddle losing pressure under hard shifting
went for a cruise yesterday and noticed that under hard acceleration from 1st to 2nd when i press the clutch peddle it only returns about a quarter way back up and goes as hard as a rock.. after pumping the peddle 2-3 time it springs back into place. works fine under normal driving conditions only goes screwy during hard acceleration.. any ideas?? no noticeable leaks either. as far as i know its the stock clutch
Your TOB/Slave unit says its had enough. Time for a clutch job. Pick up the GMPP clutch kit upgrade for the LSJ from CrateEngineDepot. Comes with an upgraded clutch and the new design TOB (LNF) unit. Will run you about $300 but its money well spent, promise.
This isnt a part to cheap out on. Dude needs a GMPP upgade. Mays well only split it open once and do a whole clutch job in the extra 10 minutes it takes then just replace the tob and yank it apart again to do a clutch later. Im sure OP has at least 50k on it.
Its well over $80 on rockauto and pretty sure Sachs is not OEM.
