CM s4/ZZP s4
Old Dec 29, 2010 | 03:19 PM
SOHC24powa's Avatar
CM s4/ZZP s4
my clutch is shitting the bed and im stuck between these two clutches. I want to keep my stock flywheel and i plan on having the dealer do the labor so i dont run into warranty denial later on. the service guy asked me to contact the company that sells the clutch and to find out if its ok if the flywheel is resurfaced, he said some companies design their clutches with close tolerances. i'd like to here everyones pro/cons, personal exp. to help me decide. also, how much torque can each hold. and not percent , id like to know numbers please and thank you.
Old Dec 29, 2010 | 11:48 PM
AyrtonSenna's Avatar
I'm installing the clutchmaster stage 4 with flywheel soon. I can tell you how it is once i install it if you want
Old Dec 30, 2010 | 12:17 AM
SOHC24powa's Avatar
any help is appreciated. lmk.
Old Dec 30, 2010 | 12:24 AM
Scythe_Snake's Avatar
I personally have the ZZP South Bend Stage 4+ and I have had ZERO issues. I am also big turbo putting down 420whp 420wtq on a mustang dyno. Feels good, engages good, tough but good enough to daily drive.
Old Dec 30, 2010 | 12:38 AM
SOHC24powa's Avatar
stock flywheel?
Old Jan 4, 2011 | 03:01 AM
ronn's Avatar
I don't get this?? They're gonna give you a warranty on an aftermarket clutch?? Even if it's for labor...how can they do that?? If the aftermarket takes a SH##T, they're gonna cover labor for another one? WOW!
Old Jan 4, 2011 | 03:18 AM
ronn's Avatar
Hope you intend to race this car a lot:
CM4:
Warning: Due to the solid (no Marcel) friction rivet design, the FX400 disc engages very quickly and may chatter slightly in first and reverse. To help alleviate this problem, we only use premium ceramic friction material
CM3 is segmented Kevlar and will be MUCH easier to drive in the street. Not saying CM4 will be a problem, since guys here use pucked discs. Just a heads up. If you wanna race it hard...then that's the ticket. Keep in mind, there's no *free lunch*..grippier clutch is harder on the tranny.
Old Jan 4, 2011 | 04:03 AM
SOHC24powa's Avatar
They want cover clutch stuff. Just don't want them denying a grenaded tranny or snapped axle because some other shop installed the clutch.
Old Jan 4, 2011 | 04:16 AM
SOHC24powa's Avatar
CM4:
I doubt the CM3 will hold the torque. I need a clutch that'll hold 400ftlb.s. I've driven 6puck sprung clutches before, no different from full face disc. As long as the disc is sprung no problems.
Old Jan 4, 2011 | 06:41 AM
ralliartist's Avatar
tagged, I'm interested in this as well. Only I need something that will hold north of 500wtq and 600whp.
Old Jan 4, 2011 | 02:46 PM
ronn's Avatar
The ZZP 4+ has more clamping power using same ceramic full face disc..2300lbs vs 1900 for Stage4..so that might be the ticket.
Old Jan 4, 2011 | 04:13 PM
SOHC24powa's Avatar
Yeah I know zzp's is good to go. I guess I phrased the title wrong. Maybe cmiller can chime in on how the CM4 holds up?
