Does shifting early damage the clutch?
Old Nov 24, 2011 | 11:47 AM
StevoElSupremo's Avatar
Yeah please dont shoot me if this has been asked before but... I heard that shifting a 4banger at around 1500-2000RPM on a SMOOTH road with only enough load to keep it moving is damaging to the clutch and that I should be shifting at like 3-3.5
is this true or false?
Old Nov 24, 2011 | 11:49 AM
Powell Race Parts's Avatar
false so long as you dont slip the clutch
Old Nov 24, 2011 | 11:50 AM
lol ok thanks ^ (actually heard it said on OCC haha)
Old Nov 24, 2011 | 12:05 PM
wiki:
Progressive shifting is a technique for changing gears commonly practiced by drivers of semi-trailer trucks. It is meant to reduce fuel consumption — something very important for drivers who travel several hundred miles each day.
Progressive shifting is accomplished by changing gears upward as early as possible when accelerating. After each shift is completed, the engine and transmission should be operating at or near the lowest rpm speeds recommended by the manufacturers of those parts.
When done properly, progressive shifting often results in quicker acceleration because diesel engines produce the most torque in lower rpm ranges.[citation needed] Additionally, this technique reduces wear on the transmission because synchronizers only need to compensate for relatively small differences in rotational speed between different components in the gearbox.
As defined by KE =1/2 mv^2, acceleration is the process of gaining kinetic energy, so greater the power delivered, the quicker it gains kinetic energy.
The best average acceleration in a truck with a Caterpillar C15 engine is achieved by going all the way up to 1950RPM, then shifting to a gear that will put the engine at 1500RPM, so that the truck is receiving as close as possible to maximum power throughout the entire time it is accelerating.
Shifting at peak torque doesn't provide the maximum acceleration as even the engine maybe making the maximum torque, with each up shift, the mechanical advantage of the transmission is reduced.
Old Nov 24, 2011 | 12:20 PM
Dart_SI's Avatar
i have heard it puts slightly more strain on the clutch, because more torque is being applied, but yeah, what powell said. i usually shift anywhere between 2-3k tho.
Old Nov 24, 2011 | 12:28 PM
Cobalt_Daddy's Avatar
as long as your car isn't shaking and chugging trying not to stall you should be fine.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
2009blackSS
Sep 30, 2015 05:57 PM
