View Poll Results: Downshift or neutral
Downshift
284
52.50%
neutral
257
47.50%
Voters: 541. You may not vote on this poll
Downshift or neutral??
i brake,
the tranny is for shifting
the brakes are for stopping
i like to let each thing do what its best at
if its just to slow down a bit while moving and im at low rpm's (under 2000ish) ill downshift though
because its horribly unsafe in a lot of situations.
what if your coasting to a stop and you get bumped hard in the ass coming up to a red light.
you will get shot further into the intersection if your in neutral, because your free rolling.
Your engine reduces your brake distance.
being in neutral increases it.
what if your in an accident while your coasting and your knocked out.
your car will continue rolling if your in neutral.
theres an inordinate amount of situations where its just stupidity to neutral coast.
Its dangerous and illegal.
please don't do it.
please don't do it.
And I don't know about you, but If I get rear ended I am ON the BRAKES!!! I had a manual transmission 2004 Pontiac Sunfire with the same drive train combo as this G5 has...Got rear ended while I was coasting to a stop (coasting doesn't mean I'm off to F'in Brake!!! means it is in the gear I started to brake at while my foot is on the brake) The guy was doing 55, I was doing 20 and slowing (foot on brake!) I get hit, and hit the brakes harder, I didn't move any more than if I was in an Auto!
Its called Use your F'in head folks, not be some douche saying 'YOU MUST DRIVE LIKE ME CAUSE I AM BOSS AND I KNOW WHAT THE HELL I'M TALKING ABOUT, AND I WORK FOR A COMPANY THAT WILL FIRE MY ASS IF I'M CAUGHT COASTING!!!'
I in my life have never heard of such a thing, and I have neighbors who have been trucking for 20+ years. They down shift only when they need to, they never use the clutch except for first, and when coming to a stop, them rigs have some really good breaks... And also out on the road, I never hear a truck down shift unless it is to slow down really fast and he switches on the jake brake, even though it is highly illegal to do so in town around here.
message to the disgruntled know it all! Get a life, if someone drives differently, it doesn't mean they are driving wrong, it just means you are pissed off at someone, and have to take your anger out on folks who don't do what you do!!!
PS: Automatics drop to N when you are coming to a stop, and the Torque Converter unlocks...They go back in gear when the tiniest bit of gas is applied! So, N stopping against the law??? Must need to pull over anyone driving an Auto now too, eh?
Dude, seriously WHO THE HELL TAUGHT YOU HOW TO DRIVE??? THE manual CLEARLY states if you have a Manual Transmission that you should always leave it in the gear you were in when coming to a stop and then pull it out just before coming to a complete stop (around 1200rpm)
pros- None.
safes gas? no
Saves engine wear? no
Saves clutch wear? no (providing you know how to rev match when downshifting)
safes gas? no
Geezus people! No wonder Dealerships Throw out the warranty on manual transmissions a lot lately...no one reads the manuals. And drives the way they seen some fast and furious freak do it.
Although I'm not sure why it's called "double clutch?" Basically just match the revs to what they will be in the next gear, so that the shift is smooth.
Double clutching means you save money. Less gas. Less brake wear. No added clutch or TO bearing wear.
So if there's no fuel going into the engine when in gear and deccelerating, does that mean there is no exhaust either? I'm not saying I don't believe you, because you seem to know what you're talking about, but that just seems odd to me.
LoL @ all of you fast and furious double clutchers have fun, they make synchros for a reason. Double clutching is for trucks, like big trucks, not for cars.
Downshift and rev match, not only is it the least wear on you car, It also sounds hot when the exhaust is crackling.
That is not correct. You will get better gas mileage by downshifting to a stop rather than coasting in neutral. Deceleration fuel cut off (DFCO) enables during a downshift. Since the wheels are directly connected to the engine, there is no need to add fuel. When you are in neutral, fuel is added to keep the engine running obviously.
If you want to start quoting random people as your proof:
"Perhaps it depends on how the manufacturer set things up. My C5 Vette DIC (Driver Information Center) instantaneous mpg indicator always indicates some fuel is being used even with closed throttle decel on a long grade. My wife's Audi (1.8T) instant. fuel econ. computer hints at no fuel being used in a similar condition with fully closed throttle. Cracking it just the least amount gets it back on the scale around 200 mpg, the upper limit it shows. Both of there cars are throttle-by-wire.
My conclusion is that the GM engine may not completely shut off the fuel during closed throttle decel. I have tried different gears (A4) on long downhill grades, and instant mpg is slightly different in 3 vs 4, but not anywhere near the ratio of the gears.
Some GM automatics with their "fuzzy logic" will downshift to lower gear(s) if you are in a closed throttle decel (coming down a long grade), and the vehicle speed is still increasing. This gives more engine braking, which is a safer thing than coasting at idle with the trans disengaged.
FWIW, if you have a mpg computer, watch instant. mpg during your normal driving, especially before the cold engine gets to normal operating temp. 3-5 mpg. at light acceleration is common with a cold engine, while it will double or better when the engine is warm. Of course letting it warm up without moving gives zero mpg, so driving away moderately right after start is the way to go. Many owners manuals say just that."
"It is the throttle follower, part of DFCO, Deceleration Fuel Cut off. A pain and doesn't work for the good of fuel economy or a good coast down.
If you watch your fuel injector PW, watch it as you decel and count the seconds it takes it from cruise or acceleration to actually bring the injectors to a 0 PW. It doesn't do it much, if ever. I am working on my LT1 to get more agressive DFCO, but it is still a pain to get working right. GM likes this 2.5 second delay before DFCO even starts. So look for that, you are likely fighting the DFCO delay."
"The DFCO has a slew of settings to make it function well.
DFCO Delay
DFCO Enable RPM
DFCO Disable RPM
DFCO Enable MAP
DFCO Disable MAP
DFCO RPM Drop Rate (if the engine drops rpm too fast it will add fuel back)
DFCO Ignition Timing
So with all of this you can do a pretty good job at cutting off the fuel on decel. Unfortunately, GM has it setup so it RARELY ever activates too. So that is pretty bad in my book...."
These quotes are all from LS1Tech
Nice try Alleycat and Witt.
I guess the best way to determine the truth to this is do what the first guy said, and reset your DIC's MPG while your doing this coasting/downshifting and see what it reads as your instantaneous MPG. Then you will know the truth. All cars are different, so what someone know about one car is not necessarily true about all.
Also, could someone please find me a written law that states coasting to be illegal. That is the dumbest thing I've ever heard on this site. When was the last time you heard of someone getting a ticket for coasting. Come on people, use common sense.
DFCO Delay
DFCO Enable RPM
DFCO Disable RPM
DFCO Enable MAP
DFCO Disable MAP
BTW:
Indiana - illegal to coast in neutral going down a hill
IC 9-21-8-44
Coasting in neutral when traveling upon a down grade; prohibition
Sec. 44. (a) A person who drives a motor vehicle may not coast with the gears of the vehicle in neutral when traveling upon a down grade.
(b) A person who drives a commercial motor vehicle may not coast with the clutch disengaged when traveling upon a down grade.
Ditto for Tennessee:
Coasting Prohibited
The driver of any motor vehicle traveling on a downgrade
shall not coast with the transmission of the vehicle in neutral.
Vehicles shall not coast with the clutch disengaged.
Same for California:
I 21710 Coasting, in neutral on downgrade.
Same with Texas - where you also get points on your license:
§ 545.406. COASTING. (a) An operator moving on a
downgrade may not coast with the gears or transmission of the
vehicle in neutral.
Colorado prohibits coasting at ANY time:
WARNING--Allowing your vehicle to coast in neutral is against state law
(42-4-1009, CRS, Coasting prohibited).
Pennsylvania it is considered driving in an unsafe manner (not being in control of a motor vehicle) if you "coast" for more than the length of the vehicle:
Unsafe coasting occurs when your vehicle is out of gear (clutch depressed or gearshift in neutral) for more than the length of your vehicle.
Cliff's Notes: It's illegal in EVERY state to coast down a hill, other states you've just got to check the laws. Or it could be like it is here and be an unsafe driving ticket, because it's just that......unsafe.
Last edited by alleycat58; May 15, 2007 at 01:57 PM. Reason: Automerged Doublepost
double-clutching is a waste of time with modern tranny/synchros...just single-clutch rev-match (using heel-toe braking if slowing down)
BWAHAHAHAHAH...zero gas....HERE IS THE ANSWER TO THIS, YOU F-ING IDIOTS:
Not to mention illegal as aforementioned.
I think you were dropped one too many times on your head as a baby.
See previous quote/response...
YES, it takes a tad bit more gas to downshift/brake than coast/brake because the engine uses more gas at higher rpm REGARDLESS OF THROTTLE POSITION. Because you are rev-matching to higher rpm upon down-shifting, you are using more gas. End of story.
DFCO Delay
DFCO Enable RPM
DFCO Disable RPM
DFCO Enable MAP
DFCO Disable MAP
DFCO Delay
DFCO Enable RPM
DFCO Disable RPM
DFCO Enable MAP
DFCO Disable MAP
2nd part It takes less gas to zing the engine up a gear then then have no fuel running thru it then it does to sit at a 14.7 idle until u come to a stop...DFCO does work on these cars so ur whole point is now counterproven
Btw using no fuel is more environmentally friendly then idling...u coasting bastards are killing the rainforests and driving illegally
Dan
Double clutching is not necessary by any means, but still does save wear. Your throwout bearing is an unlubricated part, so reving a lot with your clutch in is a bad idea.
I am not opinionated one way or another on this topic. I know what works for me, and I have never been at fault in an accident.
I have also in 3 manuals never had to replace a clutch nor have I had slippage issues.
So I am going to stick with what I have been doing.
I have this question though, and I am not being an ass about it, so please dont take this the wrong way all of you pro-downshifters.
But, for those using the gas saving argument, but are mimicing the actions of an automatic drive train, how would that save you gas?
I was under the impression that manuals got better gas mileage because of the fact that you can coast in neutral.
Those that said the engine uses no gas when you down shift, are just wrong.
If you are going 50 mph, and down shift, but are completely out of gas, your engine isnt going to run on magic. If your RPM's are above anything but 0, you are using gas.
Also, I dont know about other states, but I know when I lived in New Mexico that there were signs on the highway prohibiting trucks from using the engine to slow down.
Just a thought.
I dont advocate coasting in neutral, because most accident situations (in my experiance) can be avoided by being on the gas, but I also dont subscribe to down shifting being better than braking. I say a good mix of the two and smart driving are the keys to success here.
Just a thought.
Just a thought.
Just a thought.
In coast down it is using 0 fuel until u reapply the accelerator...that is how u save gas
Hmmm.,, this so far has been quite informative. I've been neutral coasting for so long that I'm wondering why it really is not enforced. At least I've never been ticketed for coasting downhill, but speeding, inspection, registration, proof of insurance, failure to stop, exhibition of acceleration, not using turn signal, failure to yeild, etc... but never coasting.
This really is a helpful site, thanks everyone
And chipsgt, best post of the thread. I still feel funny about this whole thread, because I am not a "coaster" Although I do it sometimes, generally I am downshifting, but spend a little longer in neutral than just going straight to the next lowest gear. Basically a slow downshift. Whatever, I just like debating I guess.
As for the laws posted about it being illegal, I noticed that all specifically note that it is illegal ONLY WHEN GOING DOWN HILLS, nothing about regular flat roads. No **** it's dangerous to coast down a hill. Jesus. No one's arguing that. It can't be that horribly dangerous if it's not enforced either. Has anyone ever heard of someone getting a ticket for coasting?
LMAO, will we now? Is that why if you start the car at a top of a hill, reset the DIC, and coast it reads 99.9 MPG????? I'd rather trust a gauge that reads what's ACTUALLY going on fuel wise (wideband) rather than a gauge that displays an arbitrary (and easily inaccurate) calculation.
The 99.99 MPG is an instantaneous readout, it's saying that is what mileage you are getting at that moment. Obviously it cannot sustain that, because of gravity, wind resistance, etc. If you think the DIC is inaccurate, then you should think anything that connects to your car is inaccurate, because they are both connected to the ECU. Haven't you seen those guys that can sqeeze like 100 MPG out of a typically 30 MPG car. Someone posted it on here a while back, but I couldn't find them. I can guarantee you they are doing more coasting than downshifting.
No one has yet to provide a response to the post about the directions in the owner's manual. Why would GM say that is the preferred method?
