Emergency Cv Axle help!!!
i just tried to change my cv axles today thought i had the right parts and following a you tube video...... well i have the wrong axles im trying to find the right ones. any one able to point me in the right direction i really need help only have a day left to get my car running before i got back tot work.
i have a 2007 cobalt lt automatic
this is what i got
Buy GSP New CV Axle Shaft Assembly NCV10617 at Advance Auto Parts
but i need one like this
Buy GSP CV Axle Shaft Assembly NCV10615 at Advance Auto Parts
but theres 2 on there i dont know if i need 2 diffrent models or not and no store has this in stock so i dont know what to do.
i forgot about the oddball axle setup gm uses with the 4t40/4t45 on the passenger side.
what likely happened is the stub shaft that goes into the diff came out with the axle. you need to clamp the stub shaft portion into a vise and use a hammer on the end of the axle cup to drive it apart. once apart put the stub shaft into the diff (transmission, then put the axle into that. the passenger side is a female spline and will go together the same way.
bump,
sorry to bring up a dead thread but im at this again.
awhile ago i bought 2 of these:
Buy ToughOne New CV Axle Shaft Assembly NCV10617 at Advance Auto Parts
problem is on the passenger side it is to short and pulls the lower boot off the axel. theres no grease left and pretty sure its about out.
i either need
Buy ToughOne CV Axle Shaft Assembly NCV10613 at Advance Auto Parts
or
Buy ToughOne CV Axle Shaft Assembly NCV10615 at Advance Auto Parts
trying to order parts now. have appointment for tires and alignment tuesday.
i either need
or
DANRICKARD
Oct 1, 2015 12:08 AM
