F23 lnf
Old Jul 28, 2020 | 04:07 PM
SEDAN's Avatar
F23 lnf
F23 Swap in an LNF, what’s the scoop with wheel bearings? Can you use LSJ wheel bearings and uprights on the LNF with no issues?
Old Jul 28, 2020 | 04:19 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I don't think so. LSJ knuckles won't (easily) fit the larger LNF Ball Joint. It can be forced, but that generally isn't a good idea.
And I was under the impression that LNF's use the same axle spline count as LSJ's (they definitely do on the trans side)... so that wouldn't help you anyway.
I have been trying to research how to do this swap myself for my LSJ, but there doesn't seem to be one collective thread of information.
Old Jul 28, 2020 | 05:23 PM
exninja's Avatar
trans side spline is the same, hub side is different. but isn't the f23 different from both of those?
Old Jul 28, 2020 | 05:45 PM
I think you have to run the L61 wheel bearings with ABS sensor built in that are the 5x110 lug pattern
Old Jul 28, 2020 | 07:59 PM
SEDAN's Avatar
I’m already regal F40 swapped, but a friend has an LNF that needs a clutch and wanted to swap to an F23 while doing the clutch.
we are unsure of what wheel bearing and upright combo needed to run f23 axles and still retain all ABS as it was implied in another thread that the ABS would be non functional with f23 hubs and uprights.
Old Jul 28, 2022 | 12:18 AM
bfrancom3's Avatar
Did you ever figure this out? Trying to retain ABS
User 60923
May 14, 2016 09:25 AM
vanos
Sep 16, 2014 09:51 PM
BLue NoTe
Dec 22, 2010 02:24 AM
XTC_916
Nov 30, 2008 12:13 AM
CSM Huber
Nov 5, 2007 08:18 PM
