if the air is trapped in the slave cylinder, pressure bleeding it will do nothing as the bleeder screw is in the middle of the clutch line. vacuum bleeding actually pulls the slave cylinder all the way in, and that forces the air and fluid to travel out of the slave. once the air is in the line it will slowly make it was back to the master cylinder, thats why you put them on and leave them for 15 minutes.
Thanks everyone. And yes sharkey I have thought about that a little bit. One thing I know is in the past when I removed ONLY the clutch line while leaving the slave in the transmission full of fluid I didn't have a bit of problem bleeding it. However this time I was starting over with a new empty slave/TOB and it is giving me way more trouble, which makes sense given what you said about the bleed location. It took me forever just to get some fluid to it initially.
Originally Posted by Sharkey
(Post 7683000)
Originally Posted by jdbaugh1
(Post 7683189)
I'm sure that will do great for the brakes and help with the clutch, but I still think you need to pull vacuum on the system to help remove any air bubble at the TOB |
Originally Posted by ECaulk
(Post 7683194)
Anyone else getting a re-direct to walmart from this click?
If it doesn't pull a vacuum then I misunderstood what the product is and need to cancel my order. There's honestly not a good product description anywhere on this that I can find that clarifies how it works.
Where the hell can I buy a vacuum bleeder that will work with Cobalts?
Will this work? |
I canceled the order on the power bleeder because I didn't look close enough at what it was. Everyone in here was talking about vacuum bleeding and that power bleeder is the only product anyone shared. I orderdhttps://cimg7.ibsrv.net/gimg/www.cob...25b8a3dd64.jpghttps://cimg8.ibsrv.net/gimg/www.cob...7e4c24d8b6.jpg
Hopefully with both of these products I should be able to pull a vacuum on this damn thing. |
If you can i'd cancel the Lisle one. You can just get a tub stopper from Home Depot and a bleeder nipple from Autozone and make one that works.
And yes, the help wasn't very clear. The pressure bleeder is helpful so that you can bleed the brakes without pumping the pedal (and having to open and close the bleeder valve). Sharkey alluded that you need to vacuum bleed vs. pressure bleed but didn't explicitly state that the motive power bleeder wouldn't get you there. it is still a good buy to save a bunch of time.
I canceled the power bleeder but ordered the two items I took a screenshot of. It appears to me that needing to bleed clutch lines with a vacuum isn't typical as all vacuum bleeders are advertised for power steering pumps that I could find. I figure with these two items combined I should be able to vacuum bleed anything I would ever need to so to hopefully get more use out of these tools instead of just this once.
Thanks for the help everyone. |
i have a motive pressure pot bleeder, i love the thing, it makes bleeding brakes and most clutch systems so simple. however it is the wrong tool for the clutch system in the cobalts, and a number of other modern cars that have the bleed screw in the middle of the clutch feed line.
the motive vacuum pump and bleed kit are exactly what you want. it will allow you to pull a vacuum on the master cylinder, that retracts the slave cylinder and pushes the air into the line, and itll slowly work its way back to the top. these things also allow you to pull a vacuum on a bleed screw and suck the fluid through the system, so its also handy for brakes. just a word of warning, if you ever do that make sure the little cup doesnt get to full and allow brake fluid into the vacuum pump, itll destroy it. one other thing, after you put a vacuum on the master cylinder, before you drive the car pump the brakes back up. being a shared reservoir it will suck the pistons back in the calipers. |
Vacuum bleeding working well. Pumped clutch with vacuum on it and bunch of air came out. Hopefully this does the trick |
Tested car out today and though shifting seems to have improved the clutch will still drag a bit when revving the car in gear with the clutch full depressed. I have contacted Clutch Masters to see what they have to say. Looks like I'm out $650 and many hours of labor. I'm hesitant to go back with any Clutch Masters. I've heard Exedy is a good brand? Maybe I will roll the dice again with them and see if my bad luck persists.
(Post 7683566)
Originally Posted by HGT
(Post 7683576)
Between your luck, abilities and crappy dice... I would get something different and have a professional install it. Sounds like the guy that did your transmission is still working.
(Post 7683580)
No
(Post 7683581)
No, Your tranny also has issues?
You replied "No" with No explanation...
If you aren't going to offer any useful advice please refrain from commenting further.
(Post 7683585)
(Post 7683588)
I was the only one that suggested the tests that led to the result that you have a shit plex plate or bent clutch disc. :r:
