F40 kit Discontinued?
Old Sep 28, 2015 | 03:53 PM
taintedred07's Avatar
Originally Posted by LNFwagonSS
Omg, I am soooo ******* happy right now! Had this 2400$ LSD f40 sitting here for a year now! Yes!!!!!
Did it require special gaskets or tools to install the lsd or was it pretty straight forward?
Old Sep 28, 2015 | 04:41 PM
cmiller8006's Avatar
Don't worry about the lsd man, the thing is posi all the time in a straight line. Never turned my car hard to figure out the other part.
Old Sep 28, 2015 | 04:47 PM
I hear ya, the balt will be strictly street driven, just don't wanna regret it later on down the road I guess.
Old Sep 28, 2015 | 05:43 PM
LNFwagonSS's Avatar
Without LSD at the track with stickies you should be fine with the exception of a one wheel peel once in a while. It benefits more on the street or anywhere with less avail traction. Still, it is undeniable that an LSD will benefit strait line traction.
And yes the f40 is stupid easy to work on. Only tools needed are for diff bearings. You will want to measure the diff play side to side and shim it so it has the same or slightly less play depending on mileage and wesr.
If you change any other bearings, same procedure.
Old Sep 28, 2015 | 06:15 PM
LNFwagonSS, Ryan D. Matt M and myself did not run a lsd and it was perfectly fine. Not saying its not better, its just there are other areas to put that money.
Old Sep 28, 2015 | 06:28 PM
LNFwagonSS's Avatar
No doubt. $1100 diff is a huge pill to swallow.
Old Sep 28, 2015 | 08:18 PM
If I wasn't doing a whole build then I'd consider it.
Old Sep 28, 2015 | 08:34 PM
LNFwagonSS's Avatar
Hell, you can always add it later if you feel you need to. Could be done in a weekend. Would only take one day to pull trans, install diff, and re-install trans if you didn't have to wait for case sealant to dry.
Old Sep 28, 2015 | 09:11 PM
LNFwagonSS's Avatar
Just got an email back from ZZP. They are not ready. It was supposed to be put in the site as PRE-ORDER only. But it sounds like things are moving along at least. Send Kyle or Matt an email and let them know you intend to purchase as they plan on having 10 kits available and appearantly, 4 of them are spoken for, including myself.
Old Sep 28, 2015 | 09:17 PM
I'm sure they will go gast
Old Sep 28, 2015 | 10:13 PM
  #36
Thank you for the heads up!
Old Sep 29, 2015 | 10:16 AM
  #37
crashher0's Avatar
I saw their listing on their shop site says its back in stock. They really only have 10 for sale?
I am leaning more towards keeping my Sedan as a DD not screwing with it anymore and pricing out an LSJ built engine. (If I ever land on some money) An LSJ Turbo second gen S10 is in blueprints in my head as of right now.
Old Sep 29, 2015 | 11:30 AM
  #38
LNFwagonSS's Avatar
They don't have any ready for sale right now, they are still refining a couple parts. One of which is probably the speed sensor. I'm sure they will produce more kits after they are able to re-coupe some money on the first batch.
Old Sep 29, 2015 | 11:48 AM
  #39
crashher0's Avatar
probably the speed sensor..
This is what I have heard from everyone I have talked to. these 10 are probably their next test batch to see how it works outside of testing
Old Sep 29, 2015 | 12:16 PM
  #40
LNFwagonSS's Avatar
Honestly, I don't see how it will ever work correctly on the half shaft. The issue is with calculated milage AFAIK. As in, it will calculate less miles than you have actually driven. Lol I'm OK with that though! Don't quote me on this as it didn't seem Matt was entirely sure of the the exact issues.
Old Sep 29, 2015 | 12:46 PM
  #41
Grave's Avatar
I think cruise control not working was also one of the issues.
Old Sep 29, 2015 | 01:03 PM
  #42
breds2k's Avatar
Wont have the money for one of these any time soon but I enjoy monitoring the progress!
Old Sep 29, 2015 | 07:58 PM
  #43
"We are going to keep producing it. we were making some slight changes, we are done, and now the kit is available.
I cannot take a reservation on the kit. I have several ready to go.
Steve"
Old Sep 29, 2015 | 10:16 PM
  #44
LNFwagonSS's Avatar
What the hell is the deal. Kyle says its not ready and the next day Steve says they are.
Old Sep 29, 2015 | 10:17 PM
  #45
Well the other night they were $1799, noticed no flywheel/clutch included. Then today they're listed with everything for $2000.
Old Sep 29, 2015 | 10:41 PM
  #46
I know back when the first ones where hitting the streets the speedo and rpms would work correctly, but the mileage and everything to do with that was off. Never bothered me at all.
Old Sep 30, 2015 | 12:38 AM
  #47
Sounds similar to running e85
Old Sep 30, 2015 | 07:40 AM
  #48
mh167002's Avatar
I had an f40 with LSD, aluminum flywheel and south bend clutch swapped in with the zfr7163 in July and I can say it is a great combo.
My Speedo reads spot on and cruise works great, but they are still working on a fix for the trip and range. 1 mile only shows up as 3 to 4 tenths on the trip.
Old Oct 4, 2015 | 02:26 PM
  #49
LNFwagonSS's Avatar
Annnnnnnnd, the kit has been taken off the ZZP website
Old Oct 5, 2015 | 02:56 PM
  #50
InfraRedline's Avatar
I may be an exception because I'm a Redline and don't have the calculated gas mileage or miles to empty on my dash, but I have an original F40 kit and I just used the speedo input data in HPTuners from a stock 2004 Redline as a starting point and made some minor tweaks and it reads speed and miles correctly. Remember, the 2004 Redlines had an external tone ring on the intermediate shaft that the VSS read. When I first took it out it read speed and miles way off, so I started with the 04 settings in HPT and they were very close.
