First Time Buying Clutch
Hey guys, Im getting the upgraded LSJ clutch kit for my LNF, but I am wondering if there is anything else that I should get when replacing the clutch, as I have never done one before. LNF is my first manual.
I know this is debatable, but I am going with a new LSJ flywheel; its not every day the trans gets worked on, so Im doing it while I can.
8 Flywheel bolts
Anything else? I see CED has a LNF TOB spacer, and thats the stuff I have no idea if I should order or not.
Thanks guys
8 Flywheel bolts
Thanks guys
GMMP Clutch Kit comes with:
-New pressure plate
-New clutch disc
-New LNF TOB
Add in:
-8 Flywheel to crank bolts
-A new OEM flywheel
-A new OEM clutch pipe
You can buy that spacer if you would like, but I cannot comment on its effectiveness. I have done a couple GMPP clutches for people and did not use it, even on my own car, and everything was perfect.
-New pressure plate
-New clutch disc
-New LNF TOB
Add in:
-A new OEM flywheel
-New pressure plate
-New clutch disc
-New LNF TOB
Add in:
-A new OEM flywheel
-New pressure plate
-New clutch disc
-New LNF TOB
Add in:
-A new OEM flywheel
Yes sir.
You reuse the pressure plate to flywheel bolts. They are not torque to yield.
LSJ FW is not debatable. I have one in my LNF. It is perfectly fine. Just to make sure I got a LSJ pressure plate to use with it.
I have never tried to put the LNF PP on the LSJ FW tho.
Yes sir.
breds2k
19
Sep 21, 2015 10:24 AM
The Rookie24
Sep 20, 2015 04:33 PM
