fixed my shifter issue! (wasnt the roll pin)
Old Oct 19, 2011 | 07:12 PM
Dart_SI's Avatar
so i posted a thread a month or so ago about my shifter being sloppy and pretty notchy.
i had about a inch to an inch and a half of play side to side while i was in gear and shifts just felt plain notchy. my shifter plain felt like poop.
i thought it might be the roll pin, but after close inspection they still looked brand new. plus i couldnt get them out to save my life
soooo i purchased a new stock shifter and installed it about an hour ago. took it for a drive and im very pleased
my shifter feels much tighter and shifts feel less notchy. theyre still notchy but thats most likely because i need to change my transmission fluid. shifting feels so much better and more precise now and all that extra slop is gone!
so if your having any issues with your shifter being sloppy and replacing your roll pin doesnt help, try replacing your whole shifter assembly.
Old Oct 19, 2011 | 07:17 PM
outtamymind's Avatar
good to know but still doesn't get down to exactly why it starts to feel sloppy, mine feels the same way, to me it feels like too much play in the shifter.
Old Oct 19, 2011 | 07:22 PM
Dart_SI's Avatar
side to side or front to back? i know exactly why my shifter started to get sloppy once i removed the old one. ill post some pics in a few minutes and explain.
Old Oct 19, 2011 | 07:25 PM
Rissa's Avatar
You shouldn't have to change the transmission fluid in the car unless you beat the **** out of it or have over 100k miles.
Old Oct 19, 2011 | 07:30 PM
Dart_SI's Avatar
you shouldnt have to, but sometimes it just helps. when you break the car in sometimes you get a lot of metal shavings floating around in the trans. happens to most cars, plus it cant hurt.
when i had my old 2006 civic SI my shifting started to feel notchy, it started popping out of 3rd gear, and missing 2nd at WOT. changed the trans fluid (at 25K) and all those problems went away for the remainder of the time i owned the car (sold it at around 45K miles)
mongorat427's Avatar
Yep and I just got 3 more new ones for sale with clips.
http://i931.photobucket.com/albums/a...s/100_3981.jpg
Old Oct 19, 2011 | 07:32 PM
Dart_SI's Avatar
lol. it helped a lot. this shifter is diffrent than the one that was on my car tho, my ss/tc had a leather wrapped knob and my reverse lockout mechanism was blue instead of white.
Old Oct 19, 2011 | 07:34 PM
i've done mine twice already but i race it in the summer and its winter driven and our winters can get pretty extreme. and yes i know its a lil over excessive lol :S
but yes OP i would love to see pictures
Old Oct 19, 2011 | 07:35 PM
Dart_SI's Avatar
alright, the thing i noticed the most when i removed the old shifter, the spring i have circled here in red was worn pretty good. i believe thats why i had so much play side to side and why it felt sloppy.
btw this isnt my picture, borrowed it from mongorat
Old Oct 19, 2011 | 07:36 PM
that could definitely do it, less tension on the spring could cause a loose feeling. makes sense to me
Old Oct 19, 2011 | 07:41 PM
Dart_SI's Avatar
also i think this part contributed. it was also worn down.
Old Oct 21, 2011 | 12:16 AM
D-mac's Avatar
Should have just installed a TWM Shifter
Much better
Old Oct 21, 2011 | 12:31 AM
soundjunky's Avatar
I don't buy this...
many transmssions problems down the road can be prevented by regularly changing the oil... *with the correct stuff*
Old Oct 21, 2011 | 01:06 AM
i upgraded mine to the synthetic stuff, not cheap either and its the GM mtf :S
Old Oct 21, 2011 | 01:16 AM
DiabeticKripple's Avatar
i changed mine with the stock ac delco ****
Old Oct 21, 2011 | 11:53 AM
Rissa's Avatar
I don't buy this...
That was straight from an engineers mouth since I was considering changing mine...said I didn't have to till about 100k unless I was racing it all the time. It's not just generic transmission fluid in there lol.
Old Oct 21, 2011 | 01:06 PM
i would say depending on the climate as well, rissa i do agree with you that really it doesn't need to be changed until atleast 100k.
but there's people like me that are a little excessive with their maintenance
Old Oct 21, 2011 | 01:14 PM
07SSYellow's Avatar
Resident Post Whore/Troll
Twm ftw!!!!!
Old Oct 21, 2011 | 01:40 PM
RHZ's Avatar
RHZ
Twm would do little/nothing to fix the spring he circled. I have a twm and mine is still sloppy guessing that I have the same issue.
Old Oct 21, 2011 | 01:42 PM
Dart_SI's Avatar
yup. i was going to say that. you could buy a new shifter and then put the twm into that one. that would help, but only if its side to side play. front to back play would be the roll pin.
Old Oct 21, 2011 | 01:59 PM
wjsigo's Avatar
Mine got really bad one day kind of out of the blue- and when I tried to shift to 5th there was nothing there. Limped home, assuming roll pins or something.
There is a bracket on the shift cables, mounted to the transmission. A couple bolts were missing and the last one was loose. New bolts/locktite and it was back to feeling like brand new.
Just a heads up.
Old Oct 21, 2011 | 08:35 PM
R1600Turbo's Avatar
Might have to do this with my 2006 LS. Having problems getting into 1st gear lately, and there's quite a bit of side to side play.
Old Oct 21, 2011 | 08:44 PM
xxxxsh4d0wxxxx's Avatar
Not true.
Again, not true.
It is not "generic", by any means, it's a 75W-85 fluid from Castrol. However, there are MUCH better fluids out there.
RedLine MT-90 for one, and by a long shot.
I have a sticky in this section if you care to "learn".
Old Oct 21, 2011 | 08:52 PM
HyperMuffin's Avatar
If you beat on your car more than the normal driver or drive it in severe conditions then it is wise to change it at about 50-60k.
Not many people know that in the service/repair manual (not the owners manual) consists of 2 different maintenance schedules. There is one for "normal" driving conditions and one for "severe" driving conditions. If you drive your car like a race car then consider yourself in the "severe" category and do your maintenance more frequently than it says to in your owners manual.
Old Nov 3, 2011 | 10:58 PM
sternerG85SC's Avatar
any idea on the part number for that whole assembly?
