front end is shaking
Old Apr 6, 2009 | 08:33 PM
fmxr47's Avatar
so i have an 06 ss/sc that i blught about a year ago, when i bought it it was already lowered and drove smooth although the tires were bald, i threw on some snow tires and a few months after i ave a bad vibration coming from what feels like the passenger front end, but it is only happening under acceleration, does not happen under braking, cruising, or engine braking, my guess is a bent drive shaft, or possibly the tie rod end. i had it on a lift at work a few weeks back and everything feld solid, i tried shaking anything and everything and it all felt good, my drive shaft does have a **** hair of free play but its very minute. any ideas?
any help appreciated, i have to get it fixed before i can head to the strip
Old Apr 7, 2009 | 06:39 AM
fmxr47's Avatar
bump? anyone
Old Apr 7, 2009 | 06:42 AM
lol i have a thread with the same prob!
Old Apr 7, 2009 | 08:24 PM
BLKLS's Avatar
We have alot of odd vibrations from bent/out of balance wheels. Try that. I have seenvibs from a bad cv joint but that was constent i think.
Old Apr 8, 2009 | 05:30 AM
already swapped my wheels to my other set, same problem
Old Apr 8, 2009 | 02:15 PM
fmxr47's Avatar
its not the wheels, i can guarantee that, but im starting to develod a huming at high speeds like highway speeds im wondering if it could be the wheel bearings
Old Apr 8, 2009 | 02:16 PM
D4u2s0t's Avatar
cv joint.
Old Apr 8, 2009 | 02:18 PM
slowswap's Avatar
Wheel bearing will make a humming noise regardless of throttle position. Usually louder with speed and when you turn from one side to another, it will get louder and quieter depending on which side wheel bearing is bad.
Control arm bushings seem to be pretty crappy on these cars.
Old Apr 8, 2009 | 03:08 PM
tdipowered's Avatar
ball joint....first get an alignment and your wheels balanced...
Old Apr 8, 2009 | 04:08 PM
fmxr47's Avatar
well, im know the one wheel bearing is bad, but im wondering if that would cause the vibration, cause my buddies montecarlo was humming like mine and whn ever you turn you can hear the diference with the weight off of it.
Old Apr 13, 2009 | 04:40 PM
whatd you ever end up finding?
Old Apr 14, 2009 | 10:04 AM
fmxr47's Avatar
nothing yet, ive been busy, i start my new job today as motorcycle tch, and i had ben rounding up all my tools and loading up my tool boxes
Old Apr 28, 2009 | 09:23 PM
fmxr47's Avatar
bump?
Old Apr 29, 2009 | 11:24 AM
did you find anything?
Old May 1, 2009 | 12:50 AM
mmcgee123's Avatar
axle if it only does it under accel
Old Jun 1, 2009 | 05:45 PM
fmxr47's Avatar
so i took my car into my buddies shop today, and it is my transmission causing the problem, it is making a grinding sound, and the guys at the shop seem to think it is the input shaft and the shaft the clutch drives off of. so basically i need to get it fixed, or get a used tranny, a new one is $1600, and that ain happening
Old Jul 29, 2009 | 05:07 PM
carlu27438's Avatar
Was this vibration intermittent?? I have the same problem (under acceleration only) but one moment it's there and the next it drives perfect!! It has me stumped. I checked everything. I balanced tires, rotated tires. Mine is a stick also. I hate to think I have to replace my trans. The vehicle only has 36K miles on it!!
Old Aug 9, 2009 | 10:51 AM
kitchener ss's Avatar
I had the same problem.... it was the spindle side that the ball joint sits in, it swelled open and would no longer tighten up.... so i needed a new spindle .... hope this helps...
Old Aug 15, 2009 | 01:04 PM
osocool1's Avatar
i have the same problem but mines just the axle....i dont mean to be bother but i think i would have another look at it to make sure it was a tranny problem.
Old Aug 15, 2009 | 01:10 PM
JonyyB's Avatar
Site Founder
Hahha I ma having the same problems on my car now. Better get it checked out
Old Mar 18, 2010 | 11:26 PM
osocool1's Avatar
so what fix it????
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
