Gears....????
Old Jan 18, 2008 | 06:48 PM
srowler9's Avatar
Gears....????
anyone have different gears than the stock 4.10? just wondering because the one they have modded that they race on the track, has 4.55? No one ever talks about gears.
Old Jan 18, 2008 | 07:06 PM
warrenb213's Avatar
i wish the cobalt ls' had a longer second gear......it roughly adds half a second to the 0-60 having to shift there. bleh.
Old Jan 18, 2008 | 07:14 PM
srowler9's Avatar
ya, well the ss/sc has gears that are to long, especially 3rd. Trade?
Old Jan 18, 2008 | 09:00 PM
warrenb213's Avatar
i'll swap you second gear?
Old Jan 19, 2008 | 10:01 PM
srowler9's Avatar
has anyone done a gear swap
Old Jan 19, 2008 | 10:02 PM
lsjwannabe's Avatar
pulley down and it gets shorter trust me
Old Jan 19, 2008 | 10:03 PM
06black's Avatar
stock final drive is 4.05:1
and no, not many(if any) have done a re-gear.
Old Jan 19, 2008 | 10:06 PM
lsjwannabe's Avatar
only thing i would change is first
06black's Avatar
i want a taller set of any thing.
drop at 70 and theres still no traction....
Old Jan 19, 2008 | 10:08 PM
lsjwannabe's Avatar
**** who races slower than 70 anyway lol. I want a ride, do you supply depends or do i have to bring my own.
Old Jan 19, 2008 | 10:09 PM
srowler9's Avatar
my third gear just seems to high. It goes, and goes, and goes. I want to know if anyone has swapped for that 4.55 gears, and if so how does it feel?
Old Jan 19, 2008 | 10:10 PM
lsjwannabe's Avatar
your car just needs some more mods. AS far as i know the only way you are changing your gears is by going 6 speed and your looking at 5500 to do that
Old Jan 19, 2008 | 10:20 PM
srowler9's Avatar
I cant find the site, but GM used 4.55 gears in their modded balt. It was still the 5 speed.
Old Jan 19, 2008 | 10:34 PM
06black's Avatar
its possibile to swap your final drive, its just a ring/pinion gear set, nothing extreme but still none that i can think of have done it.
that long 3rd gear will win more races for you then loose.
not shifting, and letting the car make power for a longer time in the "peak" zones is always good.
i plan on driveing 420+whp on a stock final drive, it suits a big turbo real nice.
bring your own, and DONT dirty the recaros!
Old Jan 20, 2008 | 12:39 AM
Greased's Avatar
LOL, i posted a thread in the 2.0 lsj tech section like three seconds ago , guess i got the wrong section
Old Jan 20, 2008 | 12:43 AM
BigTizzle903's Avatar
yea i wish the ls's gears were longer, second ends around 50-55 and third ends at like 70-75
Old Jan 20, 2008 | 01:27 AM
RaineMan's Avatar
I just want a taller 5th... cruising on the interstate at 3000+RPM just kills the mileage... if we could do 70 turning 2000 RPM we'd get like 40MPG.
Old Jan 20, 2008 | 02:00 AM
Shanman's Avatar
i get 45 mpg going 45, at 60 i get 38, and at 80 i get 29, the digital mpg gauge has been proven to be accurate to .2 mpgif working properly. and the cobalt that they race has a shorter final drive for quicker acceleration i think it's 3.55 not 4.55. Why worry about only 1 gear, that would throw other gears off and bog the next if set too short
Old Jan 20, 2008 | 11:43 AM
srowler9's Avatar
it was 4.55. Our cars come with 4.10. 3.55 would make the gears even longer than stock????
Old Jan 20, 2008 | 01:56 PM
Stl06LS's Avatar
Yes, the higher the number the lower the gear.
Old Jan 20, 2008 | 06:59 PM
HunterKiller89's Avatar
you think your 3rd gear sucks? my one complaint about the auto....4sp
my 3rd is my 1:1 and i have like a 3.85 final
nce i hit 70...m car becomes a brick
Old Jan 21, 2008 | 12:21 PM
montecarloman's Avatar
There is a guy on another forum that has looked at installing a 5 speed from an 05 Cavalier. He had the gear break down compairison, I'll see if I can find it and post it up later.
Old Jan 21, 2008 | 12:23 PM
lsjwannabe's Avatar
interesting
Old Jan 21, 2008 | 05:26 PM
it was on this forum in the general discussion board
Old Jan 22, 2008 | 09:03 PM
I managed to find what I had seen previously and did some investigation. Unfortunate the comparison in question involves the F35 MU3 in a SS/SC and the F23 M86 which is the current 2.2 and 2.4 manual transmission. The 03-UP cavalier has the same transmission so a conversion is pointless for anybody except a SS/SC owner. It is known however that the transmission mounts between the 2 transmissions are different and would require cutting the F35 mounts out and welding in F23 mounts. From what I can see the F23 M86 has a closer gear set which would keep the 2.0 in its power band and yield a higher 5th gear for better mileage. Here’s the link with some other info https://www.cobaltss.net/forums/show...avalier+ecotec
I also found F25 M86 which is apparently a 6 speed (don’t know where it’s been hiding) GM PART # 22622126. Checked it at Gm parts direct and it came up a good number but is a Quaife Upgrade F25 to 6 Speed, huh? Why GM has a Quaife Upgrade F25 trans as a part number is beyond me but the ratios look good for road racing. Also the Quaife F35 6 speed conversion looks real good but is really $$$.
