gm lsj upgraded clutch
i am gonna buy a new clutch i was wondring if i should get the Lsj upgraded clutch from crate engine depot along with the flywheel they offer
i never got the flywheel and mine is fine. but the tob and clutch pipe is recomended
no need for flywheel... i have the upgraded clutch on my car and i have a TVS and its holding great!!
i mean the flywheel bolt and clutch pipe. i think the tob comes with the kit.
so the flywheel wouldnt help nor hurt my car?
does it have the stock feel? |
yea mine feels stock and real easy to drive
Would an aftermarket flywheel such as ACT work fine with the gmpp clutch kit?
my friend has this clutch, he's fully bolted with stage 2 and loves this clutch. this is what i'll be getting in the future when mine goes. for now stocks still holdin strong!
what TOB comes with that kit? is it a LSJ TOB or LNF TOB, always heard the LNF was an upgraded TOB for the lsj's
lnf
the kit includes LNF throwout bearing. the flywheel that was asked about is a stock replacement, so there will be stock feel. lightweight flywheels are not necessary for daily driven street cars
if you are getting the flywheel, get new flywheel bolts, as they are torque-to-yield, meaning they can only be used once. the clutch pipe is not absolutely necessary, but is not a bad idea |
Originally Posted by Tennpenn83
(Post 5684354)
this i do not know...
Not sure about the act flywheel either, but I have the gmpp lsj clutch upgrade with a new stock flywheel and it works great. I got some goodies on my car, I last dynoed at 263 whp and it holds no problem. I will be putting my tvs and 80's in next week and we'll see what happens then. It Should be fine tho.
I no this is an old thread but, for those of you who said that a new flywheel is not needed did you resurface yours or just put the new clutch in?
Originally Posted by Eds06Cobaltss
(Post 7318060)
Hoping you might be able to answer something, I had the GM performance clutch installed on my 06 cobalt ss 2.0 and used a fidanza flywheel. When I left the shop, the clutch engages barely 1/4" off the floor and has almost no play. Is this normal with this performance clutch, or did the shop do something wrong? Let me clarify, when I press my foot on the clutch, nothing happens until I am about and inch and a half off of the floor. It used to start about 1/3 of the way down, not all of the way down.
Gmpp doesn't recommend resurfacing if shifting at high rpm
The reduced thickness of the stock flywheel can cause shifting issues at 8k... I have experienced this first hand |
