help!!!!!
help!!!!!
my clutch is shot!!! im gonna buy the lsj upgrade kit from ced.. now my question is do i need to buy a new flywheel or just get mine resurfaced?? do i need anything else?? ced says clutch pipe, not even sure what that is... i already got a zzp adjustable clutch rod... any help would be great!!!!! thanks
im not sure what else you will need but if you get the gm upgrade clutch kit from ced id get the flywheel aswell its pretty cheap. my guess is that if you wanted ur flywheel resurfaced it would cost u around the same if not more as the brand new flywheel. so id pick up the new flywheel which i plan on doing soon too btw. so im interested in what people are going to tell u u need with it. i know there are a couple other things but idk wat.
pp bolts come with flywheel bolts order 8 new can just get it resurfaced, prob wanna get the clutch alignment tool and clutch pipe while you're at it they're both listed on the same page as the gmpp kit on ced
just one of those things that if you're doing it might as well replace for peace of mind, its like 10 bucks or somethin
Cobalt Clutch Pipe 24422067 - Crate Engine Depot
clutch kit comes with a new throwout bearing also forgot to mention
