Help! Losing clutch pressure
Old May 2, 2013 | 05:15 PM
Kcohagan's Avatar
My father is a mechanic and we are both very puzzzled. I have put in a brand new clutch and master cylinder in the past 6 months (by a trans place). However i randomly lose clutch pressure and cannot get the shifter into gear. once it has happened after 20 minutes of highway driving (without shifting) then as i get off the highway i have no pressure and have to pump up the clutch. and it happens in city driving sometimes. i also noticed my clutch goes very close to the floor within minutes of starting to drive. any input would help. i have not found a pattern to it. so i cant recreate it for the trans place.
Old May 2, 2013 | 05:22 PM
jonathan923's Avatar
sounds like the tob is going...this has happened in many cases including me
Old May 2, 2013 | 05:26 PM
user 72239's Avatar
This.
Old May 2, 2013 | 05:32 PM
Kcohagan's Avatar
what is a tob?
Old May 2, 2013 | 05:42 PM
through out bearing
Old May 2, 2013 | 08:12 PM
user 72239's Avatar
through out bearing
Its Throw, Mr President
Old May 2, 2013 | 08:30 PM
rivaladore's Avatar
So you didn't put in a new tob when you had your clutch changed
Old May 2, 2013 | 10:10 PM
Kcohagan's Avatar
Idk, he may have. I'll call tomorrow. Any other suggestions if that's also new?
Old May 2, 2013 | 10:29 PM
rivaladore's Avatar
It's probably bad especially if its an oem lsj tob, you need the lnf tob. Did you check your brake fluid resivoir? Has it ever went low and you filled it up? Brakes and clutch share Same resivoir if it went too low maybe air got in the system and is caiusing your issues. just a suggestion but probably a bad tob
Old May 2, 2013 | 10:31 PM
Kcohagan's Avatar
Oh forgot to say its a 2006 ss/sc
Old May 2, 2013 | 10:35 PM
rivaladore's Avatar
I know, but you still need a lnf tob, the lsj one was revised for a reason. I get cracked up everytime when I read gm's build book on the upgraded clutch and it says the tob doesn't need to be replaced and doesn't mention a break in period when upgrading to the gmpp clutch.
Old May 3, 2013 | 12:47 PM
lmao thanks for fixing that idk what i was thinking
Old May 5, 2013 | 10:04 AM
Kcohagan's Avatar
So I should get an lnf tob and give it to my trans guy to put it? Or get a new lsj one? Cause he probably won't warrantee a lnf one
Old May 5, 2013 | 10:57 AM
user 72239's Avatar
Just buy the LNF one, its the same throw out bearing but revised so its much better. Tell him its a revised LSJ if you have to.
Old May 14, 2013 | 10:27 AM
simonlamprecht's Avatar
Have you checked your slave cylinder? I have seen slaves with internal leaks that have that kinda problem. And a tob would cause a load noise when you push in the clutch if it was bad. Pressure loss happens when there is a leak or the linkage is not right.
Old May 14, 2013 | 10:31 AM
Sox-Fan's Avatar
Got Brakes?
slave cylinder?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
SSLOW06
Oct 1, 2015 07:21 PM
