hittin a wall
hittin a wall
Ok so when i try to put my car in 1st gear sometimes it just wont let me it feels like im hitting a wall. I usually just pump the clutch again or put it in 2nd then 1st it doesnt do it alot but often enough for me to get aggrivated. also when i put it reverse once it did the same thing but only once. i was just wndering what this could be
thnks guys good to know it isnt really a problem ^_^ also how do you know if a clutch is loose or getting loose? like i feel like the friction zone has gotten a little bigger. is that a loose clutch or what?
I had this problem.. First Gear/Reverse would not engage.. Well few days later.. 2nd/4th Gear wouldn't engage felt like nothing was there lol.. Well Syncro's went bad.. 48,000 miles. Ruined my tranny its in the shop right now for repair and woah u better hope yours is under warranty. Because this is goona cost a **** load
Not happy just a heads up take it in to have it looked at while under warranty :P
Did, They didn't want to cover it.. We finally worked a deal out I pay for Labor and new pressure plate since it burned up.. Clutch and fly wheel buffed out.. Getting a new transmission though
Sucks i have to pay labor err
hey if your still under warranty or know someone or just search for it on here in the how to section... check your roll pin... is your shifter loose at all. is there play in it when your in gear or is it solid... even if not i would still check the roll pin. do you powershift?
I was told by the mechanics that 1st/reverse (being the same gear, just connected in two different ways in this transmission) don't have syncros.. the reason you can't get into first gear unless you're under 10-15 or so.
JonyyB
Nov 3, 2005 01:41 AM
rm25x
Mar 21, 2005 02:16 PM
