Hub Part Numbers
Old Dec 16, 2010 | 10:31 AM
mongorat427's Avatar
Hub Part Numbers
Oem Front LNF 15793213
2010 CHEVROLET COBALT SS 2.0L 1998cc 122cid L4 FI Turbo (X) DOHC : Brake/Wheel Hub : Axle Bearing and Hub Assembly Wiki Price
TIMKEN Part # HA590088 More Information About this Part Ball Bearing; 4.33 in. Bolt Circle Diam; 5.511 in. Flange Diameter; 3.085 in. Flange Offset; Modified Flange Shape; 64.967 mm Wheel Pilot Diam
FWD; Front Disc brakes; Rear Disc brakes; Rear
Part Image
$110.99
Add to Cart
TIMKEN Part # HA590070 More Information About this Part Ball Bearing; 4.33 in. Bolt Circle Diam; 5.393 in. Flange Diameter; 1.533 in. Flange Offset; Modified Flange Shape; 64.967 mm Wheel Pilot Diam
FWD; Sport Suspension; Front
Part Image
$115.99
Add to Cart
TIMKEN Part # HA590068 More Information About this Part Ball Bearing; 3.937 in. Bolt Circle Diam; 5.201 in. Flange Diameter; 1.533 in. Flange Offset; Modified Flange Shape; 56.487 mm Wheel Pilot Diam
FWD; 4-Wheel ABS; Non-Sport Suspension; Front
Part Image
$121.79
Add to Cart
NATIONAL Part # 512250 More Information About this Part Hub Assembly
Rear Wheel
Part Image
$125.79
Add to Cart
NATIONAL Part # 513206 More Information About this Part Hub Assembly
Front Wheel
Part Image
$132.79
Add to Cart
SKF Part # BR930317 More Information About this Part {#15793213, 21995732} Bolt circle diameter A=4.4881"; Wheel PIO diameter=2.5577"; Number of splines=30EA; Inside diameter=1.3287"; Hub PIO diameter=3.5433"; Flange offset=1.5354"; Flange diameter=5.3937"; Brake PIO diameter=2.5766"; Bolt hole size=.403(3)"; Bolt circle diameter B=4.4881IN
SS; 2 required per vehicle; Front
Part Image
$156.79
Add to Cart
SKF Part # BR930430 More Information About this Part {#10399802, 15798483, 22721886} Flange offset=3.0905"; Wheel PIO diameter=2.5577"; Hub PIO diameter=2.3622"; Flange diameter=5.5118"; Brake PIO diameter=2.5766"; Bolt hole size=M10X1.5(4)"; Bolt circle diameter B=2.6574"; Bolt circle diameter A=4.3307IN
SS; w/(FE5) Suspension; 2 required
Link RockAuto Parts Catalog
I put the right number in there for the Timken front.
Old Dec 16, 2010 | 10:37 AM
Not sure about the Timken # for the front. It may be wrong. It Is wrong the Right number is HA590070
Old Dec 16, 2010 | 11:24 AM
JHans5774's Avatar
Is this for 5x110 or the 5x114?
Old Dec 16, 2010 | 11:25 AM
5x110
Old Dec 16, 2010 | 01:08 PM
Heres the other cars that use the same part number as the LNF 15793213
Chevrolet
Classic
2004, 2005
Front
Front Hub Assembly
w/ABS
Chevrolet
Malibu
2004, 2005, 2006
Front
Front Hub Assembly
Chevrolet
Malibu
2004, 2005, 2006, 2007
Front
Front Hub Assembly
Chevrolet
Malibu
2004, 2005, 2006, 2007, 2008
Front
Front Hub Assembly
AXLE BEARING - 2, 4 WHEEL ABS
Chevrolet
Malibu
2004, 2005, 2006, 2007, 2008, 2009
Front
Front Hub Assembly
INCLS AXLE BRG - 4-WHL ABS
Chevrolet
Malibu
2009
Front
Front Hub Assembly
AXLE BEARING - 4 WHEEL ABS
Chevrolet
Malibu
2010
Front
Front Hub Assembly
Not Mfr Data - Derived from OE - Match to Original~AXLE BEARING - 4 WHEEL ABS~OE: 15793213
Pontiac
G6
2005, 2006
Front
Front Hub Assembly
ABS
Pontiac
G6
2005, 2006, 2007
Front
Front Hub Assembly
w/BEARING~4-WHEEL ABS
Pontiac
G6
Front
Front Hub Assembly
Pontiac
G6
2007
Front
Front Hub Assembly
4-146 2.4L DOHC, V6-213 3.5L, V6-3564 3.6L DOHC~4-WHEEL ABS
Pontiac
G6
2009
Front
Front Hub Assembly
Saturn
Aura
2007, 2008, 2009
Front
Front Hub Assembly
AXLE BEARING
Old Jan 11, 2011 | 11:17 AM
G6 Spindles work on lnf
Old Apr 7, 2012 | 10:19 PM
gray ss/tc's Avatar
Subd
Old Apr 7, 2012 | 10:25 PM
MastaShaKe_88's Avatar
clik
Old Jul 8, 2012 | 10:48 AM
rayek's Avatar
I am bringing this post back from the dead, I just spent yesterday replacing my hub assemblies on both sides, I had purchased a set from advanced auto making sure they where for a turbo 2.0 5 lug with ABS. Imagine my JOY when I discovered the inner diameter was too small to fit the axles. I then spent 3 hours running around every part store in 3 towns trying to find the correct part only to discover that EVERY STORE had the same part under different brands, all listed as being for a 2008-2010 2.0 turbo SS 5-lug with ABS.
I finally found the proper set by just rifling through wheel hub assemblies at NAPA and comparing the inner diameter, the set I found where listed in their computer as being for the Cobalt SS LNF but didn't pop up in the system.
Now to the problem at hand, the wheel bearings from NAPA are bad, not grinding anymore but these things are giving a high pitch hum that is driving me mad so I need to replace them again but I really want to try to find some high quality replacements but I cannot go through the same mess of finding the right ones and searching online has pulled a ton of parts numbers like this thread has, most with differing inner diameters. Does anyone have the exact part number that they used?
Old Jul 8, 2012 | 04:24 PM
Heres the trick on our LNF cars. Order hubs for the same year G6 or Malibu or Aura. Their identical and use the same ABS and a lot less costly than buying the exact same part labeled Cobalt SS LNF
Old Jul 8, 2012 | 05:52 PM
rayek's Avatar
maybe easier? I am just wondering if those models also have multiple sizes in the hubs for different axles like the SS does.
Old Sep 17, 2012 | 08:53 AM
slowbaltroc's Avatar
Rear Timkin Hubs
There has been some wuestion on the rear Timkin hubs. THe number that I find everywhere is HA590088, but I have rear/ heard that that is wrong and the real part number is HA590080. Any imput on this? Thanks
Old Apr 4, 2015 | 09:08 AM
Joe09SS's Avatar
so which number is it for the rear? HA590088 or HA590080
Old May 25, 2019 | 09:31 AM
ThePanduuh's Avatar
Necro thread sorry, correct Timken rear hub for LNF is HA590080 I just replaced yesterday with no issues. I put on HA590088 before and sent ESC crapping out, don't know if it was a fluke but the one ending in 80 work without issues.
steven2008ss
Dec 7, 2011 02:10 PM
ecot3c inside
Oct 11, 2010 08:37 PM
GM>urpos
Aug 25, 2009 07:00 PM
OrngBalt
May 29, 2008 09:53 PM
