Ingalls ETD bent
Old Jun 2, 2006 | 09:41 PM
dervin3's Avatar
Ingalls ETD bent
Anyone else have this problem? During my 3rd run I had horrible wheelhop so afterwards I checked under the hood and the dampener got bent pretty bad...I'm pretty sure I'll need both brand new brackets now....and hopefully stainless steel too...
Old Jun 2, 2006 | 09:44 PM
Badmunky's Avatar
Your not the only one man. Check in the performance forum. There is a big post on it in there.
Got pics?
later
Old Jun 2, 2006 | 09:48 PM
dervin3's Avatar
my parents have my cam at the beach so no pics...The smaller bracket may be able to be saved but definately not the larger one....will Ingalls send me another set of brackets under warranty?
Old Jun 2, 2006 | 09:51 PM
dervin3's Avatar
On a positive note though, during that particular run I was against this sweet ass STi that definately was not stock....man that thing sounded mean...anyways the tree was messed up so a track official acted as the tree for us and I only lost by a car lenth. If this was a 1/4 mile I could have beat him cause I was definately catching his ass. He just got out of the hole so good I didn't have enough track to catch him.
Old Jun 2, 2006 | 10:23 PM
Badmunky's Avatar
Did you use the washers when you installed it?
Old Jun 3, 2006 | 12:36 AM
dervin3's Avatar
Sure didn't...
Old Jun 3, 2006 | 01:24 AM
Badmunky's Avatar
Hmmm.
Im starting to think that this thing is not all its cracked up to be.
So far no T/B has made it more then 4 months wiht no problems.
later.
Old Jun 3, 2006 | 01:28 AM
CTCOBALTSSS's Avatar
This is not good news. It sounded so promising. It's even on front page news on this site for stoping wheel-hop.
Old Jun 3, 2006 | 01:37 AM
06black's Avatar
havent heard any of the problums with the Torque Forward pices.....check them out.
edit----
p.s. yea that stuff needs to be covered by warrenty....call them and ask.
Old Jun 3, 2006 | 11:00 AM
distillion's Avatar
just goin the motor mount route, i can deal with a few vibes.
Old Jun 3, 2006 | 11:06 AM
BlackSS05's Avatar
ive had my torque foward for about 2 months and no problems.
Old Jun 3, 2006 | 11:21 AM
MarcS's Avatar
The Stig
Well unfortunately there is only a 90 day limited express warranty which excludes any implied manufacturers' warranty. Which is in the following contract/warranty language:
The foregoing warranty is in lieu of all other warranties expressed or implied including but not limited to any implied warranty of merchantability, fitness, or adequacy for any particular purpose or use Ingalls shall not be liable for any special, incidental or consequential damages whether in contract, tort, or otherwise resulting from the use of or the inability to use the product.
So if you break it after 3 months you are S.O.L.
Old Jun 3, 2006 | 11:29 AM
CobaltSS422's Avatar
That's bullshit. TheExorcist(chris) was telling me his bracket is starting to bend as well. Could this be why they tell u to keep it on the factory setting when installing it? The brackets are aluminum, that's probably why they are bending
Old Jun 3, 2006 | 12:42 PM
dervin3's Avatar
Yeah I might just get my uncle to fab me up some stainless steel ones
Old Jun 3, 2006 | 12:46 PM
hatrickstu's Avatar
you sure they are aluminum?
Old Jun 3, 2006 | 01:24 PM
I think so
Old Jun 3, 2006 | 01:57 PM
denny's Avatar
I think so
Guy's Please make sure to install them correctly....before blaming the product. I have made numerous runs with my car and no bent braquet. When you install the Damper make sure to adjust the lenght of the Damper's arm so that its the same as the braquets.
The 2 bolt's should go in 100% straight or else of course your going to bend the braquets.
Old Jun 5, 2006 | 12:43 AM
BooSSted's Avatar
What is the point of it being "Adjustable" if you can't adjust it without bending the brackets?
I actually took mine off the car because it was getting too noisey and annoying.
Old Jun 5, 2006 | 12:46 AM
MarcS's Avatar
The Stig
I finally understood the directions and adjusted mine. It had A LOT of vibation in the car, then I fixed it and it's slightly more vibration over stock.
Old Jun 5, 2006 | 02:19 AM
that's how mine is now.. hope those directions helped from my Ingalls from this post...https://www.cobaltss.net/forums//sho...t=21446&page=3 ....post #45
Old Jun 5, 2006 | 11:16 AM
robstamina's Avatar
I dont work for ingalls anymore....
please refrain from contacting me about any Ingalls related issues..
Old Jun 5, 2006 | 11:25 AM
BLKSS's Avatar
I asked one of the vendors how long he would expect one of these to last. He says hes been using the same one on his car for like 2 years (BS!) Im glad I didnt get these pieces of crap. Ive seen how much my engine jumps on the dyno. No way those things would work with those small brakets.
Old Jun 5, 2006 | 11:34 AM
06blackg85ss's Avatar
I've had mine for a month, hard launches too , at first I didn't have them lined up correctly and had a lot of vibration. I re-istalled them the right way with the holes lined up properly, less vibration and no bending...
Old Jun 5, 2006 | 12:00 PM
denny's Avatar
There you go.
Old Jun 5, 2006 | 12:05 PM
denny's Avatar
C'mon now, there is no need to call a product a piece of **** I have it and have no issues whatsoever!! Like everything else this product needs to be installed properly in order for it to work and not break. I wrote a How too, I wrote a review on it and Rob from Ingalls is here answering people's questions. So please people make sure you install it properly before bashing a product.
