leaking clutch fluid
Old Jun 20, 2008 | 02:32 PM
jimbos'ss's Avatar
ok so for the past 2 days i have been leaking clutch fluid, i though it was the hydraulic flex line, so i replaced that: cost $70. turns out thats not the issue, it's the valve where you bleed the clutch from on top of the tranny, improper install so i need a diagram and the install instructions from a gm tech. i'm trying to get this car leak free so i can ship it to germany asap, i'm allready a week behind schedule.
bump for a gm tech!
Old Jun 20, 2008 | 02:41 PM
SSdan's Avatar
PM fr33k.
Or maven.
Old Jun 20, 2008 | 02:56 PM
jimbos'ss's Avatar
Originally Posted by SSdan
PM fr33k.
Or maven.
ok thanks man!
ok so i just pmed them, hopefully one of them comes on line today.
Old Jun 20, 2008 | 03:27 PM
Maven's Avatar
Youve got an SC correct?
Old Jun 20, 2008 | 03:30 PM
Raven SS's Avatar
wow that sucks jim
Old Jun 20, 2008 | 03:43 PM
Maven's Avatar
The piece your talking about is the clutch slave cylinder(the piece the hose attaches to, correct?)
You need to remove the transmission to service that, there is a pipe that goes from back side of slave cylinder into the actuator("throw-out bearing") and the bearing is around the input shaft.
Let me see if I can find you the numbers for the cylinder and the actuator, and whether or not they are serviceable seperately or you have to buy both pieces.
Old Jun 20, 2008 | 03:45 PM
Darkmanx's Avatar
The parts number is 12583857 and they go for about 120+ tax
Old Jun 20, 2008 | 03:58 PM
jimbos'ss's Avatar
no i'm talking about the elbow on top the tranny that has the bleeder valve. if it's the slave cylinder imma be reeeeeeeeeeeeeal pissed seeing as it is brand new! on a brand new tranny. but it's leaking from the top of the tranny so i know thats not it.
yes, f35 tranny
Originally Posted by Raven SS
wow that sucks jim
tell me about it, i have spent the last two day working on this damn car trying to get everything back in order, the damn cam position sensor wasn't even hooked up!
the last one i bought only cost me $96
Old Jun 20, 2008 | 03:59 PM
NWAE Cobalt's Avatar
kinda shitty
Old Jun 20, 2008 | 04:01 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Did you put the black piece back on top of the trans? The little rubber boot? If not... that's the reason for your leak... not the actual distributor. I HAD an extra one before... I don't know if I still have it.
$20 says you didn't put it on there.
Old Jun 20, 2008 | 04:02 PM
jimbos'ss's Avatar
Originally Posted by NWAE Cobalt
kinda shitty
tell me about it, my car is drooling damn clutch fluid.
Old Jun 20, 2008 | 04:04 PM
Technically... its Brake Fluid. There really isn't such a thing as "Clutch Fluid".
The black thing... did you put it on? You need a pic to know what I'm talking about?
Your distributor shouldn't go bad.
Old Jun 20, 2008 | 04:05 PM
jimbos'ss's Avatar
not the black thing but the metal piece that pops onto the top of it, maybe it is the black thing leaking though, who knows, post a pic if you got one. and yes you are 100% correct it's dot3 brake fluid.
Old Jun 20, 2008 | 04:08 PM
ya...car drooling anything is not happy
Old Jun 20, 2008 | 04:11 PM
jimbos'ss's Avatar
until this my car was leak free! minus leaking all my damn money oughta muh wallet
Old Jun 20, 2008 | 04:12 PM
I know what you are talking about... but there is a black rubber seal that seals the Distro to the Trans... if you didn't put it there, it'll drool brake fluid everywhere.
Old Jun 20, 2008 | 06:34 PM
jimbos'ss's Avatar
aha you are the **** man, now you got a part number for that seal by any chance?
bump for part#
well ordered one, my car will be drooling till tuesday........lol
Old Jun 20, 2008 | 06:44 PM
Darkmanx's Avatar
bump for part#
whats the part number?
Old Jun 20, 2008 | 06:48 PM
jimbos'ss's Avatar
24422067, it can only be ordered as part of the slave cylinder line. CED has them for cheap. so does gmpartscheap.com
Old Jun 20, 2008 | 07:21 PM
Raven SS's Avatar
so are u still going sunday jim? i got my civic i tell u what its been awhile since i heard vtec..that **** opens up like a beast..the car isnt the fastest thing out there but it aint slow thats for sure
Old Jun 20, 2008 | 07:29 PM
jimbos'ss's Avatar
yes i am, since i can't ship a leaking car, started tuning last night, turns out the car was just dumping fuel in pe mode, 9:1 afr, slowly getting it in order. haven't taken it past 10 psi yet, but it's a beast .
Old Jun 20, 2008 | 07:32 PM
Jackalope's Avatar
Careful its also brake fluid.
Old Jun 21, 2008 | 02:04 AM
bump for part#
No problem.
Old Jun 25, 2008 | 02:20 AM
jimbos'ss's Avatar
turns out the seal was all squished up in there and not seated correctly................
yah i know the reservoir serves both clutch and brakes, will bleed both systems when i'm done.
Old Jun 25, 2008 | 05:45 AM
I knew it.
And you don't need to bleed both systems. The brake lines will still be full of fluids and will work just fine.
