lsj trans oil capacity and plug locations
Old Nov 15, 2009 | 12:48 PM
rhynoj's Avatar
can anybody tell me the oil capacity of the lsj trans. and where the fill and drain plugs are roughly located(havent look yet, very cold out...). as well does it have a level indicator of some sort? a window, dipstick or just a plug to remove and see if oil leaks out.
thanks
jeff
Old Nov 15, 2009 | 12:50 PM
whyyoumadson?'s Avatar
2 quarts when its bone dry. on the driver side of the trans you will see 2 torx style plugs, one on the top and one towards the bottom. the bottom is the drain obviously. fill the tranny until it barely overflows at the top. it will then drain down a little and you put the plug back in
Old Nov 15, 2009 | 04:04 PM
qwikredline's Avatar
yes except its a metric allen key 8 mm
Old Nov 15, 2009 | 09:59 PM
oops. been awhile since i have been under there. thanks for correcting john
Old Nov 16, 2009 | 04:55 PM
rhynoj's Avatar
thanks guys
Old Nov 16, 2009 | 05:13 PM
arkkornkid's Avatar
and be sure to remove or at least loosen the fill plug before the drain plug. You never know, something could happen and you have an empty transmission and no way to fill it.
Spanky's Monkey
Mar 7, 2016 06:06 PM
chefhhr
Oct 26, 2015 10:36 PM
Cptnslo
Sep 24, 2015 09:32 AM
90white240
Sep 14, 2015 09:51 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
