need help
Old Aug 8, 2010 | 04:02 AM
slowgt's Avatar
need help
i was drivinghome from a car meet and i went into second gear and it grinded a little bit iwas like wtf then went into third fine then went into 4th and it wouldnt go in so i was like wtf again, so i called up a friend he said could be a bushing or a shift fork but i can still get it into the gears just got to pull hard. gave a friend a ride in my car and he said its most likely the shift forks.. will my car be covered under the powertrain warrenty? its a 2009 cobalt ss. car is basically stock only intake and exhaust... transmission is still stock
Old Aug 8, 2010 | 11:16 AM
Joel88's Avatar
My guess would be the synchronizers. Although since your 2009, you are covered. Warranty that ****.
Old Aug 8, 2010 | 11:26 AM
EatonTVS07's Avatar
Shift linkage
slowgt's Avatar
ya going to call on monday and see debating to put my stock intake on so they cant say anything about it
would the powertrain warrenty cover it?
Old Aug 8, 2010 | 11:28 AM
ecot3c inside's Avatar
ya you bent all your forks.. right?. My guess would be synchros, make sure your clutch is all the way in. someone messed up..
Old Aug 8, 2010 | 11:32 AM
EatonTVS07's Avatar
Pop the cup holders out and see if the linkage is out of place.
Old Aug 8, 2010 | 12:09 PM
slowgt's Avatar
i got to look tomorrow getting a new tire on it right now, but if its the shift linkage or shift forks it could be replace from the powertrain warrenty right?
Old Aug 8, 2010 | 12:12 PM
EatonTVS07's Avatar
Yes. Did you have 2nd or Reverse after 4th went out?
Old Aug 8, 2010 | 12:44 PM
Joel88's Avatar
If your not sure about your warrenty this is for 2009-2010: http://www.chevrolet.com/owners/warranty/
Old Aug 8, 2010 | 02:46 PM
blackrocky's Avatar
i wouldnt even worry about it. just take it to the dealer!
