the OFFICIAL aftermarket clutch thread
ive decided to make this thread since all the info about all the diffrent types of clutches out there for our cobalts seems to be scattered. i hope this comes as a good resource for those of you trying to buy a new clutch.
if you have an upgraded clutch please post: which car u have (lsj, lnf, le5, etc) which clutch (brand, stage) flywheel how many miles on the clutch kit how was it for driving and weather or not u recommend the clutch and why (basically if u like it or not) you dont have to be too specific, but just say enough so people can get the idea of what ur clutch is like so they can better judge which clutch to get. lets get this rolling guys! thanks! |
bump....
LNF
Clutchmaster Stage 4 6 puck ZZP Adjustable Clutch rod Stock flywheel freshly machined when install was done 5000 miles on it with about 10 track launches with slicks Great clutch for the money |
LNF
KY S3 6 puck Resurfaced flywheel ZZP rod 5300 miles, first 1000 was on/off switch. now it's mellowed out some. only thing I don't like is the high engagement point. |
pics would be great!
I know you don't see these once you put em on your car, but Ima visual person :lol: like wats a bad clutch look like, good clutch blazé blazé... |
-LNF
-Exedy Hypersingle -Exedy 8lb flywheel (came with the clutch) -About 20k -Once its broken in its real easy to drive and the pedal has a nice firm feel to it -I would for sure recommend the clutch but some people might say its pricey. I have never had it slip and the thing just grips like no other. |
LSJ
GMPP Clutch kit Stock Flywheel About 6000km It's great for driving, pretty close to stock feel. I completely recommend it. You cannot beat it for the price and feel. Out the door the kit is $300 or so shipped which includes the clutch, pressure plate and throw out bearing (LNF one). I've had no hints or slip and no clutch chatter or anything negative at all in fact. Joel |
Originally Posted by CanadianCobalt
(Post 5814409)
LSJ
Originally Posted by SOHC24powa
(Post 5806842)
LNF
LNF
Exedy Hypersingle About 4000 miles Heavy pedal until I go used to it. And it was on or off in the beginning. Definitely recommend it holds power well and it is a good clutch/flywheel combo. |
good idea subd
great idea. I like this thread.
Originally Posted by metalmedic
(Post 5814608)
Do u know what the rating is on it???
Joel |
(Post 5815218)
Yes, it is rated at 300hp but it's capable of holding much more.
Joel |
all i can say is that my spec 3+ on my 2.2 held for about 1200 miles until i spun the pucks off.
(Post 5815506)
thanks.... i need me a new clutch and i think u jst won...lol
I think I'm gonna go for ZZP rod, and Clutchmasters stage 3.
I'm only 310whp/377wtq |
HHR SS LNF (2.0)
Spec 3+ Spec Aluminum Factory TOB/Slave 5k miles Installed by me Clutch engaged low on the floor initially but after 1k miles is close to stock height. Pedal pressure is slightly stiffer then stock, but not much. I do not use a ZZP adjustable rod and don't plan on it, to me that is a band aid fix, sort of like the extended slave cylinder rods on other cars. It took some getting use to the lighter flywheel , you have to rev the engine more to take off in 1st gear. Car boosts/acclerates faster with aluminum flywheel in each gear, but you have more boost drop off in between the shifts. Clutch chatter when clutch is cold and goes away after a few heat cycles. Clutch holds the power and torque of my BNR GT2871 turbo without slipping. If I had to do it again I would get the Spec Stage 3+ made to go on the factory flywheel and have it resurfaced. or I might try the Kentucky clutch next since its cheap and works with the factory flywheel. |
05 LSJ SS Turbo Converted 23psi
Spec Stage 3+ New stock fly wheel countless miles taken to the track countless digs, 40,60,80 rolls with break boosting and still holds like brand new. I couldn't ask for a better daily clutch, after break in it fells exactly like stock. http://i21.photobucket.com/albums/b2...0/DSC00963.jpg |
Originally Posted by HHRSSouth
(Post 5815724)
HHR SS LNF (2.0)
Originally Posted by klloyd
(Post 5815522)
Same here, where can I get one??
Get it from www.crateenginedepot.com, in fact this is it. Ecotec LSJ Clutch Upgrade Kit 19212712 - Crate Engine Depot Joel |
Thanks, now I gotta get around to ordering it. They really should include the alignment tool though.
Originally Posted by A.J.
(Post 5816128)
i have the same set up but i keep blowing out tob seal. Have u had any probs ? im taking it all back apart sometime today and im going to use the stock pressure plate and flywheel ,with my spec clutch disk. i think my flywheel or pressure plate is made wrong. This will be number 6 tob thats been installed. there going out due to hyper extending. What are the odds of me getting a bad clutch or flywheel ? but over all it never slipped once.
i guess its just my luck
I have an 08 cobalt sport. Full bolt ons now, but going sc as soon as I save up money for the clutch. This is my first stick car so I've never dealt with clutches before so I have some questions. I plan to only run stock pulley, and car is a DD. I won't be racing it all the time.
- I wanna get a Spec stage 2 clutch. Is spec good? Is there a better recommended clutch? - Is it ok to use the stock flywheel, or should I get aftermarket? I hear lightweight is no good though. If stock, it must be resurfaced correct? - Does trans fluid need to be drained when changing a clutch? If not is it recommended to change fluid anyway? Especially if I'm going sc. - I should use Mobil1 Dexron ATF synthetic blend for the F23 right? It says on the mobile website "Mobil DEXRON-VI ATF is a high performance, synthetic blend automatic transmission fluid formulation designed to meet the stringent service fill requirements of GM’s Dexron-VI specification." - What is TOB and do I need it? If so where do I get it? - Clutch definitely needs to be re-bled correct? (sucks if yes I just bleed it 2 months ago what a pain in the @$$ lol) - Do all new clutches come with an alignment tool or do I need to buy one? Anything else I might need to know? |
