Oil Changes
Old Mar 30, 2005 | 09:10 AM
BJC's Avatar
BJC
Oil Changes
When should I do the first oil change? I'd always heard you should do the 1st one earlier.
Also how many miles/km's should I wait before switching to Mobil 1?
I'm referring to the 2.2 engine.
Old Mar 30, 2005 | 06:47 PM
tiny's Avatar
if you break it in properly, and plan on driving aggresively, id change the oil 500-1000 miles
Old Mar 30, 2005 | 07:02 PM
zinner's Avatar
Moderator Alumni
The Cobalt has an engine oil life system. It tells you when to change the oil. The manual does say if you accidentally reset the oil life system you should change the oil after 3000 miles. The SS/SC has mobil 1 from the factory.
Old Mar 30, 2005 | 11:49 PM
tiny's Avatar
so can i do one after 500 miles, then the computer will tell me when to do all of the next ones?
Old Mar 31, 2005 | 10:17 AM
Halfcent's Avatar
I'm old school
first change between 500-1000, second change at a total of 3000 miles. After that, whatever schedule you normally use (I'm every 3000). I don't know what the on-board system will tell you.
Old Mar 31, 2005 | 12:44 PM
zinner's Avatar
Moderator Alumni
When you change the oil your supposed to reset the oil like system to let it know. So if you changed it @500 miles you would reset it and it would start the count down from there. I am not sure exactly how it monitors the engine oil. But from what I have read it looks like the computer monitors the engine and your driving habits and uses that information to estimate the oil life more accurately. I know myself I almost never change the oil at exactly 3000 miles. I check the oil and see if it's down, if it looks darker, ect. The oil life system just does a better job of doing that objectively.
Old Mar 31, 2005 | 03:28 PM
tiny's Avatar
so how do you reset it?
Old Mar 31, 2005 | 06:29 PM
Voodoosoup's Avatar
My Boss and VP at work both drive BMW's, 7 and 5 series.
They run synthetic and the maitenance schedule for oil is changin it every 15,000 miles.
I'll ask tomorrow if that applies to the first change as well.
I've read studies that are still going strong at 18,000 plus miles on synthetic with just a filter change.
The manual says that in ideal conditions you could go for a year without changing oil.
But that you should change the filter once a year at least.
THe oil life monitor works off of engine temp and rpm readings.
Old Mar 31, 2005 | 06:30 PM
Voodoosoup's Avatar
I'm pretty sure that you just bring up the oil life on the DIC and then the button on the right resets it. I'd have to double check the manual to be sure......
Old Apr 2, 2005 | 11:12 AM
BJC's Avatar
BJC
No, you have to go into the preferences menu.
Old Apr 2, 2005 | 01:58 PM
zinner's Avatar
Moderator Alumni
So I looked at the oil life system a bit more. Basically the computer in the car monitor engine parameters like engine heat and driving style and uses that information to give a more accurate estimate of when to change the oil. GM said it helps people from changing the oil every 3000 miles which isn't really needed in most cases. This way you change the oil when it's actually needed so you don't waste oil on unneeded changes over the life time of the car.
So in essence the engine oil life system is smarter and more objective than us humans at knowing when to change the oil.
Old Apr 2, 2005 | 02:08 PM
ToxicPoison's Avatar
I don't know about you, but I will be happy when our electronic overlords come to rule.
All hail the machines!
Seriously though, thats cool..if it works.
Old Apr 2, 2005 | 11:51 PM
rm25x's Avatar
I did my first oil change at 2000 miles. Most were highway miles though. Switched to Mobil 1 when I did.
Old Apr 3, 2005 | 12:22 AM
BJC's Avatar
BJC
Is the new Mobil 1 Extended Performance available in the USA yet?
I haven't seen it in Toronto yet. If so, are the regular Mobil 1 and Mobil 1 Extended Performance both available and how much more is the new one?
Also any oil filters to recommend? I have never seen the Mobil 1 High Efficiency Oil Filter in Toronto.
Old Apr 3, 2005 | 11:00 PM
stlurbanpunk's Avatar
I thought the new 2.2 needed oil changes every 6,000 miles.
As far as the cartridge filters, their expensive as hell.
Old Apr 3, 2005 | 11:42 PM
iwantacobalt's Avatar
Are the filter cartridges the same as in like the 2003-up cavaliers???
cause my bro has a 2002 cavy and wow is that hard to change oil... but i have a 2003 cavy and its easy as pie .... anyone know what kind of oil filter cartridges come with it and where they are located? easy or hard to find?
Old Apr 7, 2005 | 06:23 PM
moxjake's Avatar
The oil filters go in the top of the motor.
Old Apr 7, 2005 | 07:12 PM
avro206's Avatar
Check your owners manual. I have heard early oil changes on rebuilt engines. Like a hopped up small block Chevy ect. I have never heard of it on a new factory engine.
My Dads Civic was refused its first oil change--it was too early. Honda puts aditives in the oil to aid in break-in. Not sure if GM does the same though.
Old Apr 7, 2005 | 07:46 PM
zinner's Avatar
Moderator Alumni
Change the oil when the DIC reads 0% oil life remaining
Old Apr 8, 2005 | 01:24 AM
DarthDalla's Avatar
for all you guys that now have an SS/SC how difficult was your first oil change ? there was also a few questions on exact placement of the filter. Would any of you be so kind as to take a pic of where the filter is located (if your not too busy driving it still)
Old Apr 8, 2005 | 01:58 AM
zinner's Avatar
Moderator Alumni
I am just a hair below 1k mile mark and my oil life is at about 87%. I dunno if it's going to drop really fast or if I am on pace for a 7.5k oil change mark.
So I haven't changed my oil yet and when I get it changed I will take it to the dealer to get it done.
Old Apr 8, 2005 | 07:16 AM
rm25x's Avatar
At 2k miles mine still said 78% oil life. I still changed it though and upgraded to mobil 1.
Old Apr 8, 2005 | 12:51 PM
zinner's Avatar
Moderator Alumni
You didn't reset it when you changed the oil ?
SS/SC has mobil 1 from the factory. I usually don't worry about what type of oil I put in a car, just that I change it on a regular basis. I guess with the mobil 1 from the factory I will have to be a bit more concerned on what I get put in there.
Old Apr 9, 2005 | 06:30 PM
tiny's Avatar
1k on it and you havent changed the oil?? its time!
Old Apr 9, 2005 | 09:11 PM
zinner's Avatar
Moderator Alumni
No I haven't the manual says you are supposed to pay attention to the oil life system. It doesn't say get the oil changed after the first 1000 miles. Changing oil before it's needed wastes resources and thats specifically what the OIL life system is designed to curb.
