power shifting and syncronizing rings
Old May 1, 2008 | 06:36 PM
dirt's Avatar
Canada power shifting and syncronizing rings
Ive been having troubles power shifting or even shifting some what fast when i try to my third and fourth gears let off a nasty grinding noise so i took my car in to a chevy dealership and they said that im shifting to fast and not giving the syncronizing rings time to line up and im forcing it in gear i feel this is bullshit and was wondering if any one else has had this problem also they say theres no fixing just slow down and let rpms drop right down before finishing shifting can any one help me out what can i do to stop this or fix this or ill just have to break it before waranty ends
Old May 1, 2008 | 06:39 PM
07ss_PJ's Avatar
don't power shift?
Old May 1, 2008 | 08:39 PM
chevy cobalt 08's Avatar
mine does that with normal shifting. yes go slower
Old May 1, 2008 | 09:30 PM
Ron From Jersey's Avatar
Mine does that when cold at normal rpm's. Feels like the synchros and dog teeth aren't lined up. Works ok when warm except the 2-3 shift, kind of clunks in.
Old May 1, 2008 | 10:14 PM
maverick0716's Avatar
Powershifting isn't good for the transmission or clutch.......yes, it can make your car faster in a race, but not without it's downsides.
Old May 1, 2008 | 11:00 PM
dirt's Avatar
thanks for the info guys the more the better but i lernt how to drive with a bit less horsepower so not power shifting is different for me but i geuss ill get used to it
Old May 1, 2008 | 11:05 PM
hydraze's Avatar
Practice
Old May 2, 2008 | 12:05 AM
InfinityzeN's Avatar
Slow smooth shifting man. Gass off, Clutch in, Slow (meaning don't rush) Smooth Shift, Clutch out, on Gass.
Something that might help is switching to a better tranny fluid. Though if you keep power shifting, no matter what, you'll blow your tranny. And most likely warranty won't do any good, since it will be classified as abuse.
Old May 2, 2008 | 12:14 AM
LS6Rally's Avatar
theyd have to prove abuse. i have a clunk from 2-3. i just assumed it was cause the STS isnt stock and the fitment might not be perfect. i've never raced the car
Old May 2, 2008 | 01:52 AM
On most things with the tranny, the GM rep is going to claim it is due to abuse. Then, you would have to take them to court to contest it. Good luck there.
Old May 2, 2008 | 01:55 AM
bigrroberto's Avatar
I;ve never power shifted my car...
I have no problems shifting as fast as i possibly can (not powershifting) and imapproaching 30 000 kms. So dunno man.
Old May 2, 2008 | 02:00 AM
Kazuki's Avatar
If you have the timing down for powershifting and is good at it, then your normal shifting will have almost no wear on your tranny. So don't powershift!
Old May 2, 2008 | 05:19 AM
But he doesn't have the timing down, since he is grinding it.
Old May 2, 2008 | 09:48 AM
firemanfrank's Avatar
I used to powershift (p/s) all the time when I drove/raced my 'Stangs (not in my SC though).
I was so used to it that it became 2nd nature to me.
A couple of things about it though:
  • P/S will lower your 1/4 mile times by 1/10 - 2/10 (unless your having serious traction problems)
  • P/S will cause a great deal of stress to your clutch and transmission synchros
  • P/S frequently w/o upgrading above mentioned parts, and you WILL break them
Just FYI ...
Old May 2, 2008 | 12:40 PM
dirt's Avatar
i no how to power shift i just never had the synchro rings do that on my previos car
Old May 3, 2008 | 10:42 AM
Even with me performing picture perfect powershifts, I still eventually had to upgrade to an aftermarket Borg Warner T-5 transmission to cope with the stresses of powershifting.
Only way to avoid synchro/clutch problems when powershifting is to buy a transmission and clutch combo whose torque specs are wayyy over that of the original parts.
Old May 3, 2008 | 04:08 PM
Cobalt(312)'s Avatar
Dude these transmissions are weak man. I've had my trans worked on 3 times. And when it comes down to it if your car is held up in the shop for 30 days in a year you can claim lemon law on it and fight to get a new car. But the thing is you'll get another car just like yours and it'll do the same **** especially if you mod it. GM told me the last time my car was in that basically don't come back and expect it to be fixed for free next time. So I'm filing with a lemon law lawyer to get my money back or another car because its once its paid for I don't feel like having to shell out cash every time the trans breaks. A lot of the damages caused are due to a blocker ring failure usually 2nd and 3rd, causing the synchros to chaff and teeth to brake off gears. Possibly after awhile of driving the car like there is a broken intermediate shaft, needs replacement of the shifter assembly.
Here was my most recent:
2ND GEAR GRINDS WHEN LET CLUTCH OUT
SECOND GEAR TEETH CHAFFED BAD SYNCHRO ASSMY TEETH SHEARED OFF & 1ST GEAR
ROAD TESTED SEVERAL MILES---TO DUPLICAITE-R&R TRANSMISSION
TO INSPECT---REPLACED 1ST & 2ND GEARS & SYNCHRONIZER ASSMY
REPLACED BLOCKER RINGS & BEARINGS--ALSO HAD TO CHIZZEL
BROKEN INTERMEDIATE SHAFT NEEDLE BEARING OUT WAS COCKED & STUCK IN CASE HALF-- REPLACED THE SHIFTER ASSY ON TRANS.
REFILLED & ROAD TESTED ALL OKAY THIS TIME----OLH--2.OHR---TO REMOVE BEARING CAGE & ROAD TESTING ETC.
The repair had to be authorized by a GM service manager, and they wouldn't take my car in the first day i brought it there and it was doing it i had to come back 6 times more till they took it and gave me a rental.
Old May 3, 2008 | 09:40 PM
Same thing happened when my clutch went at 6k.
Dealer said he had to get the parts and it took over a week to get everything done.
I received a rental car as well.
But I got it back, and all is good!
Old May 5, 2008 | 03:42 PM
dirt's Avatar
ok i have slowed down even let the rpms drop for 30 seconds with no gas before shifting and it still grinds once and awhile what the **** dealer tryed to tell me its normal but i dont here any others driving around making this noise
Old May 5, 2008 | 03:44 PM
M-Dub's Avatar
Howabout stop powershifting the tranny! If it doesn't want to do it then stop!
Old May 5, 2008 | 06:10 PM
Has it done it since new? If you've been powershifting all this time, you may have toasted the synchronizers already.
Old May 5, 2008 | 08:04 PM
might not do it until the car is warmed up that what mine was doing
Old May 6, 2008 | 04:54 PM
dirt's Avatar
ya it does this when the car is cold mostly ill just keep bringing it in to the dealer until they fix this. its not only with power shifting its all the time unless i shift verry slow and i only power shifted a couple time didnt do good so i stoped
Old May 6, 2008 | 09:59 PM
expansion and contraction laws
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
2009blackSS
Sep 30, 2015 05:57 PM
