Roll pin problem need help
Old Jun 22, 2016 | 01:06 PM
Jamie1234567's Avatar
Ok so my tranny quit going into gears yesterday and the stick felt very sloppy and had no feel to it so I was reading on here and found a post about that problem and how to fix it so under the fuse box on top of the tranny there is a linkage piece or something with a roll pin through it and that is in fact broke cause I was able to pull 1/4 of the roll pin out and it was broken off and I can't get the rest out, my question is how do you get it out? How do you get a punch and a hammer down in there? There just isn't enough room it seems like and I've tried almost everything any help would be appreciated thanks
Old Jun 22, 2016 | 02:46 PM
Viperoni's Avatar
Yes, a pin punch plus hammer are needed.
In my IRL I found it very very helpful to drop the tranny down a couple inches to be able to swing the hammer from the wheel well - I couldn't get it from the top side.
Old Jun 22, 2016 | 06:45 PM
63 Nova SS's Avatar
Originally Posted by Viperoni
Yes, a pin punch plus hammer are needed. In my IRL I found it very very helpful to drop the tranny down a couple inches to be able to swing the hammer from the wheel well - I couldn't get it from the top side.
^ good advice. Hammer and punch are your friend.
Old Jun 22, 2016 | 07:57 PM
06blackbalt's Avatar
Take the fuse box off you get a lot more room an put a bolt in it
Old Jun 22, 2016 | 08:14 PM
Fuse box is off and no way to drop the trans I'm doing this in my yard I don't have a shop but it seems like I can't fit a punch and hammer down there but il keep trying
Old Jun 22, 2016 | 09:00 PM
cluelessk's Avatar
Don't replace with a bolt like others mentioned.
Roll pin is designed to be a weak point tofall before damaging your trans.
Old Jun 22, 2016 | 11:51 PM
Was able to get the old pin out and the new pin in I didn't want to do the bolt idea for the reason @cluelessk said but I was able to get a short nail that I cut that was the right size for the hole cause my pin pusher was too long I didn't have any hammering room but with the short nail it makes a difference but as always thanks for the ideas and support guys really appreciate it
turbosmart4
Jun 20, 2016 07:39 AM
Hugger1975
Jun 9, 2016 01:25 AM
Ryan SS/SC
Drag Racing
26
Jun 6, 2016 08:03 PM
GreenStang
May 25, 2016 02:20 PM
