RPM Problems!!!
RPM Problems!!!
Hey,
Has anyone had a problem with their rpm falling below idle when they come to a stop with the AC on? It seems to keep getting worse. And i swear it was going to stall out last night. I am currently over my mileage for my warrentee(39,000 in 10 months of owning the car). and was wondering if it was a common problem.
Thanks
P.s.,
I have a 2006 SS S/C G85
And it sometimes does it without the AC on, but not as often and not as bad
Thanks
P.s.,
the RPMS fall spastically to 250-500 RPMS(and basically barely hangs on and you can feel the car wanting to stall) and the car does it 2 or 3 times when i come to a stop and then settles back to idle. I know it will idle a bit lower with the AC.... but never that low.
I drive 109 miles one way to work(Central Jersey to Wilmington, DE{I work for GM and build the Solstice,Sky,Opel GT, and Deawoo G2K}) so the miles rack up.
Hey,
Thanks
P.s.,
Thanks
P.s.,
Actually, I think that the car increases its rpm with the AC on. As soon as I turn mine on, my idle raises about 100rpm. I can see it on the tac.
Material? If I remember correctly, thats where all the hottie gals r at. Either you lucked out or u must have seniority. I was a floater. Paint, final line, chassis to name a few. Paint dept. still on the second level? I can still remember forgetting to unlatch that beretta off the dolly and when the robot tried to take it off... screeching and snapping as the frame of the car tore in half. unforgetable sound.. hideous and quite scary. How I didn't lose my job is beyond me.
