shifter??
Old Nov 29, 2011 | 09:21 PM
aimeee's Avatar
shifter??
since I got the car, it's always "locked" me out of 2nd if I try to shift at a high RPM. I thought this was normal so it didn't really bother me unless I was racing. now, the car will go into 2nd SOMETIMES, others it will grind, bad. I took the boot off of the shifter and saw that the linkage was bent. if I slam it into 3rd at a dead stop, it goes into 2nd like butter, but every other time it's a problem. i didn't know if these cars had shift linkage or cables? but if anyone has had or is having this problem and knows how to fix it, any help or advice would be very appreciated!!
Old Nov 29, 2011 | 09:27 PM
TommyP's Avatar
AWD > FWD
Well the linkage connects the cables. If I remember correctly TWM makes an improved shift linkage. I would try getting that, then adjusting the shift cables. Maybe try adjusting the shift cables first. If you remove the cup holder you can get to the adjuster.
Old Nov 29, 2011 | 09:34 PM
mongorat427's Avatar
If its still under warranty get a new cable first or it will bend again
Old Nov 29, 2011 | 09:36 PM
aimeee's Avatar
alright, I appreciate it!
Old Nov 29, 2011 | 09:56 PM
Powell Race Parts's Avatar
tip: Take your time shifting: It should be a 3 part motion with the right hand. Out of the gear you are in, pause in neutral. and then shift to the next gear.
trans lasts long this way.
007Buff
Jun 11, 2017 03:04 PM
biniecki
Oct 25, 2015 02:23 PM
Cptnslo
Sep 24, 2015 09:32 AM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
