shifter is so sloppy
Old Mar 17, 2010 | 01:32 PM
venum_us_2002's Avatar
I had a problem first with the shifter linkage and i adjusted it so it is even again but when i am in Neutral and not in the clutch i can move the shifter up and down a couple inches with out it engaging, is it suposed to be like that? When i shift in to gears it does not seem like it is even in gear or that it wants to pop out. I am having a friend look at it during spring break but i just wanted to know if it was something i can do. I did the shifter linkage adjustment already but that did not get rid of the slop
im thinking it is the roll pin
Last edited by venum_us_2002; Mar 17, 2010 at 01:32 PM. Reason: Automerged Doublepost
Old Mar 17, 2010 | 01:35 PM
CTcar's Avatar
Is it the stocker? I got a STS and a torque damper and that firmed up my shifts. Other then that I dk what you can do
Old Mar 17, 2010 | 03:45 PM
DaBuzzard's Avatar
I expect you are right on the roll pin - makes it feel like the cables are made of rubber, sloppy as hell, pops out of gear sometimes.
Trust you found the how to?
Old Mar 17, 2010 | 04:01 PM
yes i found the how to thanks, hoping i can make it home from school 45min drive to replace it
007Buff
Jun 11, 2017 03:04 PM
biniecki
Oct 25, 2015 02:23 PM
Cptnslo
Sep 24, 2015 09:32 AM
007Buff
Sep 22, 2015 09:48 AM
CannonBalt
Sep 18, 2015 09:13 AM
