shifting issues either stuck between 2nd 3rd need help
Old Sep 18, 2015 | 01:30 AM
The Rookie24's Avatar
Exclamation shifting issues either stuck between 2nd 3rd need help
Ok so i posted before about having issues with NLS in my 05 ss. 2nd to 3rd only this NLS works 1 to 2 3 to 4 and 4 to 5 beautifully, just with going 2nd to 3rd shifting at 6 k or so i go to shift and i get part way into 3rd and the shifter just stops no grinding no noise so i quick pull it back clutch in and push forward goes in fine jus race shifting seems to be the issue. so I get home start playing with the shifter move it around and tried recreating the quick shift and a couple time I got caught in-between 1st and 2nd. Has anyone heard of this ever happening ? I tried adjusting the cables still had the issue.I also tried this with normal race shifting let off the gas and hit the clutch instead of hold gas and press clutch still had the issues a few times its not every time but is more often then not. I have my NLS set to auto so it cuts sign as long as the gas is to the floor and clutch is in
thanks
Old Sep 19, 2015 | 10:28 PM
no_ss's Avatar
thanks
Is your car supercharged? If so idk how NLS would be beneficial for you, it would just be damaging your car.
Old Sep 20, 2015 | 02:28 PM
Yea it supercharged for now gunna be turboed in December how does it hurt it all its doing is cutting the ign for a second and keeping the throttle plate open
Old Sep 20, 2015 | 04:33 PM
O I'm using a wot box set to auto so that what i mean by cutting the ign for a second so the engine has no load when shifting
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Trav3480
Oct 1, 2015 08:17 PM
2009blackSS
Sep 30, 2015 05:57 PM
