shifting probs
Old May 2, 2012 | 09:58 PM
ayellaone's Avatar
shifting probs
my car shifts smooth through first, second but hangs up going in to third, but is fine every other gear. I got to pull the shifter back and then push toward third and some times its goes and sometimes it goes into first. My clutch engages perfectly and my transmission does not slip, sputter, or seem to be malfunctioning at all. I had read a while back that there was a shifter pin being replaced, is this the problem i am haveing.
Old May 2, 2012 | 10:09 PM
BlackLsCoupe's Avatar
darn not an lnf. i had same issue ended up getting a trans put in. but mine was a grind tring to g in third multiple times with clutch to floor. dealer told me numerous time driver error.
Old May 2, 2012 | 10:11 PM
ayellaone's Avatar
no grinding or anything. just wont go into third sometimes, i think its the roll pin. Anyone Elses .02?
Old May 2, 2012 | 10:16 PM
K-Train04RL's Avatar
Sounds like it could be the culprit. Just jam it in hard and it may snap lol. Take a look at it. Pull fuse box and it's right there look for signs of stress and stretching
Old May 2, 2012 | 10:53 PM
bluebalt07's Avatar
Probably the roll pin. Just pull the fuse box and look at it. If it's sticking out it's probably the culprit.
RaginChopsuey
Oct 27, 2015 01:27 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
dieGone
Sep 23, 2015 10:20 AM
The Rookie24
Sep 20, 2015 04:33 PM
