short throw install for 2.4s
Old Feb 11, 2009 | 01:48 AM
Zdeuce4's Avatar
I got a cavy short throw for my 2.4 since ive been seeing that it fits. one thing idk about is the install.. i saw TWM's install but are all short throw setups installed the same? i cant seem to find the cavy install instructions either so im at a loss.
Old Feb 11, 2009 | 01:49 AM
cobaltss86's Avatar
cc08 has the same shifter msg him
Old Feb 11, 2009 | 01:50 AM
orbalt08's Avatar
shouldn't be too difficult or that much different. give twm a call, they may be able to help you out.
Old Feb 11, 2009 | 01:56 AM
NWAE Cobalt's Avatar
i have one...fits the 2.2 as well...it fits...but is a little loose.
Old Feb 11, 2009 | 02:00 AM
cobaltss86's Avatar
he wants to install it help him out
Zdeuce4's Avatar
yea that^^
about it bein loose. i saw somethin on jbody.org about tightening a nut to keep it from feeling loose.
Old Feb 11, 2009 | 02:05 AM
Originally Posted by Zdeuce4
yea that^^
theres no nut to tighten....i just added a third o ring under it to tighten it up.
ok, do you know how to pull the boot off and get to the assembly??
Old Feb 11, 2009 | 02:18 AM
Zdeuce4's Avatar
yessir..
i believe mine looks like this.
minus the knob.i bought a seperate, better looking one
Old Feb 11, 2009 | 02:26 AM
thats what mine looks like more or less.
the boot fitting to the shifter is going to be trial and error for you depending on what it looks like, but usually is just a new sip tie through the loop and tightened at the top to hold it.
once you get the old boot and knob off then youll need to pull three things off.
first, there is a horizontal plastic pin that you need to push in the tabs and then push towards the drivers side. it is in the front side of the shifter and holds the white part in.
when you have that out then rotate the "O" shaped piece at the base of the shifter (holds the ball down) and use a flat tipped screw driver to push in the tabs (three of them) to get it to pop off. you will then need to pull up and towards the passenger side to pull the nub out (attatched to the side of the ball) then pull REALLY hard up to get the bottom ball to pop out.
once you have this youll need to take the plastic piece off the big ball and little side nub and transfer them to the new shifter and then reassemble backwards (dont forget the o rings)...this should do it for you!!!
let me know when you are working on it, and you need help, i have mon, tues, and wed off and illl pm you my number if you want to help with install....done this to my car twice and to a cavi
Old Feb 11, 2009 | 02:33 AM
Zdeuce4's Avatar
ur the man.. was any cutting needed? and did u actually have to take the entire shifter assembly out?
Old Feb 11, 2009 | 02:34 AM
no and no lol
the hardest part is getting the new shifter to snap back into the lower clip....but thats not even that hard, took me about 20 min last time i did it (about a week ago)
Old Feb 11, 2009 | 02:35 AM
REIGN SS's Avatar
Original Hayden Fanatic
Just goto TWM site and DL there instructions for the Cobalt, follow them and you'll be golden...
I did do the cutting as per the instructions, others haven't and been ok. Guess it's personal preference
Old Feb 11, 2009 | 10:28 AM
Zdeuce4's Avatar
i got twm's as back up.. u guys have been a big help.. ill update once i receive my shifter and install it. hopefully this weekend
Old Feb 12, 2009 | 01:12 AM
Zdeuce4's Avatar
got the pics up..
so no cutting is needed... i think i can follow the instructions. do i need to grease the stuff at all? i see how the ball is supposed to go on. wut do i need to do with the reverse lockout?
Old Feb 12, 2009 | 01:20 AM
cobaltss86's Avatar
let me know how you like this shifter i'll prob end up getting the twm tho
Old Feb 12, 2009 | 01:21 AM
chillfactor's Avatar
how did you fix the looseness exactly. and what knob is that cuz i cnt find one with that thread pattern
Old Feb 12, 2009 | 01:25 AM
Zdeuce4's Avatar
the knob didnt come with it, i bought it seperately..its an ebay company
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
and ill let u know how it is man.. ill be usin it at the bash.. come find me!
Old Feb 12, 2009 | 01:39 AM
i added a third o ring under the ball to push the plastic piece around the ball...made it all good
Old Feb 12, 2009 | 01:43 AM
cobaltss86's Avatar
i'll be getting a tune are you coming early?
Old Feb 12, 2009 | 01:46 AM
Zdeuce4's Avatar
my club is goin early friday morning to clean/prepare. im getting tuned as well.. im gonna be dumb and tune twice.. i gotta tune again once my cams come in.
Old Feb 12, 2009 | 01:50 AM
cobaltss86's Avatar
lol i think i'm gonna get a hpt from my friend then get a tune from trifecta
well i'll see you friday if i get the hpt so i can drive my car if not i'll tow my car up there and get it tuned and then see u lol
Last edited by cobaltss86; Feb 12, 2009 at 01:50 AM. Reason: Automerged Doublepost
Old Feb 12, 2009 | 01:51 AM
Zdeuce4's Avatar
under as in picture 15 under the guys fingers?
http://www.twmperformance.com/manual...n%20Manual.pdf
Old Feb 12, 2009 | 12:58 PM
under as in when you have the whole shift assembly out, and their is one oring in the hole where you tookt he shifter out...i put a second one down there, it pushes the whole assembly up and makes a tighter fit
Old Feb 12, 2009 | 01:02 PM
Zdeuce4's Avatar
ok so im lookin at , removing all the console pieces, rotating the white circle. removing that big metal clip, disconnecting the cables. removing the caps. adding an extra o ring and then reassembly? where'd u get the extra o ring from?
Old Feb 12, 2009 | 05:40 PM
an extra shift assebly lol, i have two stock shift assemblies, three stock shift knobs, two shift boots, two shifters...lolol
