Slippage
Old Mar 25, 2006 | 09:17 AM
Floridas Finest SS's Avatar
Slippage
i personally am getting clutch slipping in third and fourth between about 2800 to 3200 rpms when i floor it so i was wondering when ur getting slippage do u need to change the entire clutch or just the flywheel?
Old Mar 25, 2006 | 10:27 AM
TurboTechRacing's Avatar
It should be more the other way around. The disc is the part that slips, and wears. Then you will want to replace the pressure plate also. The option would be to put a new light weight flywheel in at the same time as the new clutch.
Old Mar 25, 2006 | 11:56 PM
Okay, I just want to immediately at this point in time fix the slipping, so what would it take to fix that? and how much would i be looking at spending? and who suplies it?
Old Mar 26, 2006 | 12:03 AM
Cobalt_Supercharged's Avatar
You have lots of options if you go to http://www.turbotechracing.com
Old Mar 26, 2006 | 03:47 PM
blackphoenix's Avatar
i think my clutch is slippin too. i notice it in first, it revs high then slowly drops and starts to move again.. and when i punch it in second it does the same thing.. but i it doesn't in any other gear.. i think when i'm hard on the throttle it slips... when i drive around town normal it's fine. this is my first stick shift, and i burnt my clutch up pretty bad learnin how to drive it.
nuttzzy
May 16, 2008 01:05 AM
Super_SS
Nov 29, 2007 07:53 PM
creepySS
Nov 18, 2007 06:20 AM
ralliartist
May 18, 2007 11:31 PM
sauced1173
Nov 13, 2006 01:30 PM
