Slipping Clutch
Slipping Clutch
after changing the clutch of my 2006 SS S/C for a SPEC stage 2+,pressure plate and new throw out bearing with a SPEC flywheel the 2nd gear of the car is less powerfull and the car is slipping the clutch in the 3rd gear when I power shift
that's after 650 miles driven after changing the clutch because SPEC recommend to drive it like 500miles before going full throttle
any help please
thanks in advance
any help please
thanks in advance
ok I understand
but that was the 2nd time i did and the first time was after about 600 miles which is more then what spec recommends. from 0 to 600 miles i drove the car shifting below 3000 RPM
I'm not power shifting now with this problem
that's what i would have thought, however, the one that came with my kit is different than the one that came out of the car, and the one that i ordered as an OEM replacement is different than either of them.
GM is the only company that makes the throwout bearing. An aftermarket TOB would be really nice. I put a new one in with the Exedy and wonder if its going to hold up to high RPM track launches on slicks.
Umm... last time i checked most if not all spec clutch kits from TTR come with a TOB...
Unless im wrong... their pictured with one anyway????
VV
http://www.turbotechracing.com/produ...dCategory=5615
VV
My exedy was fine on the 2.6 and meth but with the turbo and slicks on it started slipping into 3rd gear and then when I tried to do 2nd gear burnouts with slicks.
when i bought my SPEC kit it tells that it comes with the throw out bearing too but when i got it it wasn't in so I called them about it and they told me that i've to buy the throw out bearing from the dealer because they don't make it and the dealer is the only one who does.
