So need the advice
Ok, so I did my fair share of searching and I hear all types of different preferences when it comes to clutchs and flywheel combos. I want to hear a suggestion from anyone with a TC that had changed. I read the thread of combos but it doesn't really give me a good idea of what I need.
I need about 420 holding ability maybe a little more for shits and giggles. I dont want the RPM's to drop suddenly unless there is a significant difference in accleration with the aluminum flywheel. This is my daily driver. I like main roads but I do hit the highway. I want to be able to step on it in 3rd, 4th or 5th and not slip the clutch. What are the parts that need to be replaced? I want to spend around 700-800 for clutch and flywheel. |
whenever i upgrade my clutch, im thinking zzp stage 4 with stock flywheel resurfaced.
runnin the zzp stage4 and fidanza flywheel, 477ft lbs and goin strong. stock pedal feel.
https://www.cobaltss.net/forums/driv...review-253028/ |
Are there any modifications to the stock flywheel? Is it just plug and play?
pretty sure you can use the stock flywheel. just call and ask
I would stick with the stock flywheel, just get it re-surfaced
Lots of clutch selections out there |
