Stage 2 axles?
Stage 2 axles?
Hey has anyone with the stage 2 axles by the driveshaft shop noticed that once installed sucked the wheels into the wheel well more like a 1/2 inch.....Are these axles a little bit shorter than stocks??? It sure looks that way.
the axle doesnt determine were the wheel sits. your strut, steering knuckle and controll arm determine were the wheel sits. did you remove the 2 bolts that go between the controll arm and strut??? if so, go get an alignment, your likely cambered in
No i have the stage 2 axles and they are actually longer than stock. I personally love them cause I dont have to worry about them clicking like the stock ones do. If your running the stage 2 package i suggest buying the stage 2 axles. I have had no problems with them except when i was installing the right cv joint it didnt seem to go into the axles as much as the stock one did.. but its because the stage 2cv joints are alittle longer.
DANRICKARD
Oct 1, 2015 12:08 AM
