tengo problemo
Old Jan 6, 2009 | 01:44 PM
Joeyeljefe's Avatar
clutch problem?
ok so. i think my clutch is slipping or dieing..... here are my symptoms.. wen i have the car in gear, it seems that wen i let off of the clutch pedal it engages to easy. and wen i start to give some gas it builds the revs too quickly and does not accelerate until a couple of seconds later and then accelerates. even on the highway cruiseing at 60 and i try to give it more gas up a hill it revs higher and does not accelerate till a few seconds later wen the revs come bak down. is this a clutch problem or is it something else.
sorry if this doesnt make sense. plz ask me to re explain. HELP!!!! PLZ!!!
Old Jan 6, 2009 | 01:45 PM
brickerenator's Avatar
1. How many miles on the clutch?
2. Do you street race?
3. Do you do many hard launches?
Old Jan 6, 2009 | 01:52 PM
Joeyeljefe's Avatar
1. 41k
2. ummm sometimes.... hah
3. maybe a couple.
Old Jan 6, 2009 | 01:53 PM
ChevyRockstar's Avatar
need a new one i think from that
Old Jan 6, 2009 | 01:55 PM
there was an issue with the slave cylinder, or a related part
Old Jan 6, 2009 | 01:57 PM
Joeyeljefe's Avatar
like from the factory? mines an 05. explain more in depth plz...
Old Jan 6, 2009 | 01:58 PM
that's just it
i can't remember
Old Jan 7, 2009 | 12:43 AM
Smarty Art's Avatar
TOB is bad going to cost 125$ for the part from the dealer plus 500$ for labor at the dealer. Are you leaking any fluid out of your bellhousing or are you low on DOT fluid?
Old Jan 7, 2009 | 12:53 AM
Sharkey's Avatar
a bad slave/release bearing (its one peice) will cause the clutch to not release when you push the pedal in, and leak. it will not cause a clutch to slip.
Old Jan 7, 2009 | 12:55 AM
BLAZIN07SS's Avatar
I'm too JDM for you
this is like the third thread where i am about to respond and you take the words right out of my mouth. lol
Old Jan 7, 2009 | 12:57 AM
berto's Avatar
get a act stage 2 clutch and a fly wheel
my friend has this set up and that thing grabs like no other
unless u go exedy
riceburner
Mar 14, 2014 02:13 PM
oowah
Aug 31, 2009 10:37 PM
