Ticking noise (NOT MY ENGINE)
Old Sep 23, 2009 | 06:05 PM
MaxVQ35DE's Avatar
OK, so i can only hear this with the windows down. Roll on the throttle and there is a click, sometimes a few more clicks as torque ramps up, lift throttle clicks again. Im able to hear it drivers side the best. Anyone have experience with this issue?
Im going to have the clutch done in the future so id like to have the issue corrected while its being worked on.
Old Sep 23, 2009 | 06:09 PM
BlueBolt66's Avatar
My buddy had a problem with his axles get sloppy from wear and you could hear a clicking noise when you acelerated and left off the throttle. We changed his axles problem went away. You may possibly have some play in your CV joints.
Old Sep 23, 2009 | 06:10 PM
blackbolt89's Avatar
maybe its a wheel bearing? as you said it gets louder as speed increases.
i cant see how an 09 would be having a wheel bearing problem this soon though.
Old Sep 23, 2009 | 06:12 PM
DoMiStIc_RuSh_06's Avatar
my car has this every once and a while as well....The dealer told me its normal...lol....i also had that noice in my 06 ss/sc until i installed stage 2 axles.
Old Sep 23, 2009 | 06:13 PM
SS/SC Crazer's Avatar
i had a click in mine, at an idle, not moving, in nutral! if this is the case, move the shifter slightly, not in gear, just put some pressure on it, if the click goes away its in your transmission! i should still have a click i just cant hear it anymore because of my loud ass exhaust lol! i wouldn't be too worried about it!
1BADSS/SC's Avatar
do you have the warranty still intact?
Also, my car makes weird clicking noises due to gearbox chatter. Its perfectly normal though. Try and putting the car in 1st gear with the clutch depressed. If the clicking goes away, your car has a case of the chatters.
Old Sep 23, 2009 | 06:16 PM
MaxVQ35DE's Avatar
ok so i guess ill have them inspect the axles while theyre doin the teardown. Im at like 14k miles
Old Sep 23, 2009 | 06:17 PM
CudaJoe's Avatar
you can get a click from having rocks stuck in your tire treads or even worse a nail or a razor blade, check to make sure your tires dont have any of those especially the last two items.
Old Sep 23, 2009 | 06:24 PM
arkkornkid's Avatar
it's axle click and fairly common. I replaced mine with DSS axles and the sound went away.
It's more of an annoyance, not anything serious.
Old Sep 23, 2009 | 06:42 PM
MaxVQ35DE's Avatar
ive probably only been noticiing it lately because the weathers been great, roll the windows up, and you cant hear it at all. Ill still mention it to the trans tech when we do my clutch a few weeks down the road.
If its abnormal Ill try to get them to warranty the part and some of the labor, because im already paying for clutch labor 6-8. But they know that the clutch is coming out so the car can put down more power. All they know is that I WILL be doing some power mods later.... and the clutch is a building block.
Old Sep 25, 2009 | 10:04 AM
09blackonblack's Avatar
cv joints... my 09 2.2 does it as well i took it to the dealership on warranty they told me it was fine and normal. just like the pulling a trailer feel and the clutch slipping... my dealership is stupid... they told me it was from putting different wheels on... sooo im going to upgrade my axles and clutch eventually.
Old Sep 25, 2009 | 10:06 AM
HickOverLOrd's Avatar
A rock in one of the drivers side tires.
Old Sep 25, 2009 | 10:14 AM
JohnnySasakiMGS's Avatar
Have them re-torque the axle nuts. I had that problem several times. Replaced the axles twice and the problem kept coming back.
Old Sep 25, 2009 | 02:09 PM
1BADSS/SC's Avatar
did you ever get it fixed?
rofl this avatar is amazing
Old Sep 25, 2009 | 03:51 PM
Thanks! lol
Old Sep 25, 2009 | 05:06 PM
turboss09's Avatar
i noticed today that when i was backing into my driving it made on distinct click. So i pulled front and did it again a couple of times and noticed it only really does it in reverse. Is this normal? Sounds like its coming from driver side. It did it like once pulling out in first. And its not immediate its almost when the clutch is fully out
Old Sep 25, 2009 | 05:12 PM
That DEFINITELY sounds like the axle click I have. Go get your axle nuts torqued.
Old Sep 25, 2009 | 05:54 PM
turboss09's Avatar
so i have axle click? Anyone have torque specs on the bolts, dont really want to drop it off at dealer
Old Sep 25, 2009 | 06:47 PM
X2 I would like to know this as well. It should be covered under the 5yr 100kmi powertrain but I'd rather do it myself anyway.
Old Oct 29, 2009 | 04:01 AM
mrfitz's Avatar
Sigh... I have this too. I showed them the sound at the dealer, driving with a mechanic... Of course no one knew what it was... Oh well, if they break I have an extended warranty. I don't feel like taking the car to the dealer every 5 days... Especially because they suck. Wish I still lived at home, my pops is a super mechanic (I don't have any tools down here)
Blaaaahhhh...
Old Oct 29, 2009 | 09:56 AM
S.Cobalt.S's Avatar
I noticed my car doing this last night as well. Driver side noise, sounds exactly like a nail, or rock in your tire rolling over and clicking...Who Knows, I'm gonna look around today and see If I can find anything out of ordinary....
Old Oct 29, 2009 | 06:21 PM
MaxVQ35DE's Avatar
definetly not a rock, as it would make noise whenever rolling, this is only occuring under heavy throttle and lift throttle.
Im looking into stage 2 DSS axles in hopes of a beefy CV joints
Old Oct 29, 2009 | 09:35 PM
S.Cobalt.S's Avatar
Oddly Enough, I Heard No Strange Noises Today, No Rocks, No Nails....Hmmmm
Old Nov 6, 2009 | 07:07 PM
red06SC's Avatar
output shaft noise will also increase as speed increases
OP, check your fluid
Old Nov 10, 2009 | 07:55 PM
ff_drift_lol's Avatar
make sure your cv boots aren't leaking and check your trans/diff fluid. basically what he said^ lol
could be a weird hub or brake problem too. does the sound change when you steer?
