Traction Control and trans problem / question
Old Feb 3, 2009 | 03:12 PM
Foximus's Avatar
So the T/C light came on on my girlfriends 2005 LS 2.2L automatic. And now it won't turn of at all. I think its the warning light in the console. She also says that since the light came on, the car is shifting violently.
Its a 2005 with 50,000 miles on it. Any thoughts as to what this could possible be?
Old Feb 3, 2009 | 03:15 PM
widowedeight's Avatar
? flashing or just on.... cause they could be two totally diff problems
Old Feb 3, 2009 | 03:19 PM
Foximus's Avatar
its solidly on she says
Old Feb 3, 2009 | 03:23 PM
dunno than sorry i've only delt with the flashing type (either a misfire or sylenoid(sp) stuck open)
Old Feb 3, 2009 | 08:01 PM
celicacobalt's Avatar
happens to mine once in a while and then goes away eventually. even when i was stock.
Old Mar 20, 2009 | 03:28 PM
trentonwayne's Avatar
happened to me a lot cause i switched to e85 and i didn't have the converter set up right. usually when the engine light pops on the TC light would pop on too, but i fixed that, but in your case, the engine could be running either too lean, or to rich.
Old Mar 20, 2009 | 04:04 PM
lil_kano's Avatar
i believe it has something to do with the shifter or the ignition. check fuses. also check the shifter. iirc the issue was something broke or wasn't right on the shifter or something under it.
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
reybalt
Sep 25, 2015 08:28 PM
Coballin13
Sep 25, 2015 08:43 AM
