Trans Install issue
Trans Install issue
Ok, so ive went though almost all of the posts and threads and cant find anything more than "make sure its lined up and the wiggle/twist until it fully seats/mates".
So i had to pull the trans to replace the clutch actuator/Slave cylinder. Not only were the 3 bolts holding that in all seized and fought me but now the trans wont completely mate. I am confident that the splines are lines up because if i grab and turn one of the wheel hubs the other side turns with it no issues there. I did have to support the engine with a jack from bellow but other than that i cant see anything else that would cause it to bind up an stop the trans from fully mating. Like i was able to re-attach the front and rear motor/trans mounts and still no luck with the trans going all the way in....please any help would be amazing.
Jeremy360
Sep 3, 2008 01:27 AM
