Transmission Died!!
Transmission Died!!
So my transmission officially went on my car monday night going home from my meeting. The just seemed to not have any gears and i said wtf?! and pulled over and tried to get her to move but she wouldnt. I took the top apart to check the shifter cables but they were both fine. Looks like i am going to need a new tranny!! Ideas anyone? LSD is an option and also new clutch is one.
i have a hurst shifter, but itll move the cables, and if i look on top of the tranny itll turn that stupid bone looking thing on top of the tranny.
roll pin... billet makes a roll pin for the srt4 but not for us. gay that zzp or corny ass ottp hasnt done something to give us an unbreakable roll pin. but its a cheap somewhat easy fix. dont get scared bro.
They don't need to. Get a better grade bolt, replace, pretty much indestructable. Not idiot-proof, but close.
Trust me, check the set screw first. That thing is known to back out on the Hurst shifters, and it causes EXACTLY the conditions you're describing. A roll pin won't cause the shifter itself to spin.
I didnt mean the shifter itself spin circles i meant like theres no gears so it can go anywhere!!
Ahh noobs lol. Shifting is sloppy, so clearly my entire transmission grenaded and has to be completely replaced. HAHA
Happy you figured out it was the most common problem experienced with cobalts.
Actually had a weird problem with mine today, leaning towards a linkage problem though rather than roll pin. Went to put the car in first and there was NOTHING, just like hitting a brick wall. The lowest gear I could grab was 3rd, couldn't push it over to 1st or 2nd. And of course this happens in rush hour traffic at THE most congested intersection during the entire commute. I nursed it to the first pull-off I could get to, played with the cables, nothing helped, played with it a little bit and it started working again. Did it again when I was a few blocks from work. Gonna look at it after work and see if it's anything I can fix easily since I have no tools at all with me.
